Ana içeriğe geç
HP Pavilion 15-AB153NR Bottom Case Cover Replacement
Neye ihtiyacın var
    1. HP Pavilion 15-AB153NR Bottom Case Cover  Replacement, Battery: adım 1, 1 resimden 1.
      • Ensure computer is turned off and unplugged.
      • Slide the battery lock latch on the left to unlock. Slide from left to right to unlock.
      FixBot'a Sor
      Yorum Ekle
    2. HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: adım 2, 2 resimden 1. HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: adım 2, 2 resimden 2.
      • Slide the battery release latch on the right with continuous force from right to left.
      • Once battery pops, you may release latch.
      FixBot'a Sor
      Yorum Ekle
    3. HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: adım 3, 2 resimden 1. HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: adım 3, 2 resimden 2.
      • Grab the battery, rotating upwards and away from you. This will remove the battery.
      FixBot'a Sor
      Yorum Ekle
    1. HP Pavilion 15-AB153NR Bottom Case Cover  Replacement, CD/DVD Drive: adım 4, 1 resimden 1.
      • Make sure computer is powered off and unplugged.
      • Flip computer over so that the bottom is facing the ceiling and the hinges are farthest from you.
      FixBot'a Sor
      Yorum Ekle
    2. HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: adım 5, 1 resimden 1.
      • Using the Phillips #000 screwdriver, remove the 7 mm screw on the middle right.
      • There is an icon that looks like a CD stamped into the back panel near this screw.
      FixBot'a Sor
      Yorum Ekle
    3. HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: adım 6, 2 resimden 1. HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: adım 6, 2 resimden 2.
      • Slide the drive out from the right side of the device.
      FixBot'a Sor
      Yorum Ekle
    1. HP Pavilion 15-AB153NR Bottom Case Cover  Replacement, Bottom Case Cover: adım 7, 1 resimden 1.
      • Using the Phillips #1 screwdriver, remove the two 12mm screws located on the hinge covers.
      FixBot'a Sor
      Yorum Ekle
    2. HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: adım 8, 2 resimden 1. HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: adım 8, 2 resimden 2.
      • Lift the corner covers off of the computer using a prying tool.
      FixBot'a Sor
      Yorum Ekle
    3. HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: adım 9, 1 resimden 1.
      • Remove the six 6.5mm screws using a Phillips #1 screwdriver that are located near the top of the laptop.
      FixBot'a Sor
      Yorum Ekle
    4. HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: adım 10, 1 resimden 1.
      • Remove the remaining seven 6.5mm screws using a Phillips #1 screwdriver that are securing the back cover.
      FixBot'a Sor
      Yorum Ekle
    5. HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: adım 11, 1 resimden 1.
      • Use the Phillips #0 screwdriver to remove the two 2mm screws.
      FixBot'a Sor
      Yorum Ekle
    6. HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: adım 12, 3 resimden 1. HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: adım 12, 3 resimden 2. HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: adım 12, 3 resimden 3.
      • Use prying tools to pry the covers off of the screwholes.
      • Using the Phillips #1 screwdriver, remove the two 6.5mm screws.
      FixBot'a Sor
      Yorum Ekle
    7. HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: adım 13, 1 resimden 1.
      • Be mindful of sharp edges on computer while using prying tools.
      • Flip computer over and open so that the screen is facing you.
      • Starting at the bottom right corner, insert the prying tool and lift upwards to loosen the back panel.
      • Continue down all sides and corners of the device.
      FixBot'a Sor
      Yorum Ekle
    8. HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: adım 14, 2 resimden 1. HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: adım 14, 2 resimden 2.
      • Flip laptop back over so that the bottom is facing up
      • After all sides are loosened, remove the back panel from the device.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Nicole Vachon
989 İtibar
7 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G4, Simcock Spring 2019 UMass Dartmouth, Team S1-G4, Simcock Spring 2019 üyesi
UMASSD-SIMCOCK-S19S1G4
4 Üyeler
70 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 29
Her zaman: 1,658
