Giriş
This replacement will require the use of prying tools and screwdrivers. It can completed with moderate difficulty and within a few minutes. You will need a clear work surface. Replacing the hard drive can often solve internal computer problems such as a slow start up.
Neye ihtiyacın var
Slide the battery lock latch on the left to unlock. Slide from left to right to unlock.
Flip computer over so that the bottom is facing the ceiling and the hinges are farthest from you.
Using the Phillips #1 screwdriver, remove the two 12mm screws located on the hinge covers.
Disconnect the hard drive cable from the motherboard by sliding it left to right.
Bir başkası bu kılavuzu tamamladı.
