Ana içeriğe geç
HP Pavilion 15-ab165us Battery and Back Cover Replacement
Neye ihtiyacın var
  1. HP Pavilion 15-ab165us Battery and Back Cover Replacement, Battery and Back Cover: adım 1, 2 resimden 1. HP Pavilion 15-ab165us Battery and Back Cover Replacement, Battery and Back Cover: adım 1, 2 resimden 2.
    • Flip the computer over so that the bottom cover is facing you.
    • Slide the two locks to the "unlock" position and remove the battery.
  2. HP Pavilion 15-ab165us Battery and Back Cover Replacement: adım 2, 3 resimden 1. HP Pavilion 15-ab165us Battery and Back Cover Replacement: adım 2, 3 resimden 2. HP Pavilion 15-ab165us Battery and Back Cover Replacement: adım 2, 3 resimden 3.
    • Remove the two 8mm screws underneath with a Phillips #1 screwdriver.
    • Use a plastic opening tool to remove the plastic feet.
  3. HP Pavilion 15-ab165us Battery and Back Cover Replacement: adım 3, 3 resimden 1. HP Pavilion 15-ab165us Battery and Back Cover Replacement: adım 3, 3 resimden 2. HP Pavilion 15-ab165us Battery and Back Cover Replacement: adım 3, 3 resimden 3.
    • Remove the two plastic tabs with a metal spudger.
  4. HP Pavilion 15-ab165us Battery and Back Cover Replacement: adım 4, 1 resimden 1.
    • Remove the sixteen 8mm screws that hold the bottom cover with a Phillips #1 screwdriver.
  5. HP Pavilion 15-ab165us Battery and Back Cover Replacement: adım 5, 1 resimden 1.
    • Pull the Optical Drive out.
  6. HP Pavilion 15-ab165us Battery and Back Cover Replacement: adım 6, 1 resimden 1.
    • Remove the 3mm screws that were hidden under the Optical Drive with a Phillips #0 screwdriver.
  7. HP Pavilion 15-ab165us Battery and Back Cover Replacement: adım 7, 2 resimden 1. HP Pavilion 15-ab165us Battery and Back Cover Replacement: adım 7, 2 resimden 2.
    • Flip the computer back over.
    • Use a plastic opening tool to release the clips holding the keyboard section in place.
  8. HP Pavilion 15-ab165us Battery and Back Cover Replacement: adım 8, 1 resimden 1.
    • Close the lid and pull the screen and keyboard section up and away from the disconnected bottom cover.
    • The hard drive is NOT screwed into place on the underside of the keyboard section.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Dillon Hubble
653 İtibar
3 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G2, Rose Fall 2017 UW Tacoma, Team S1-G2, Rose Fall 2017 üyesi
UWT-ROSE-F17S1G2
5 Üyeler
14 adet Kılavuz yazıldı
Bir Yorum
Where can i buy the case? I couldn’t anywhere online??
Model - HP Pavilion 15 8th gen B&O
Jackson Beno - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 57
Her zaman: 65,838
