Ana içeriğe geç
HP Pavilion 15-ab165us Fan Replacement
Neye ihtiyacın var
  1. HP Pavilion 15-ab165us Fan Replacement, Battery and Back Cover: adım 1, 2 resimden 1. HP Pavilion 15-ab165us Fan Replacement, Battery and Back Cover: adım 1, 2 resimden 2.
    • Flip the computer over so that the bottom cover is facing you.
    • Slide the two locks to the "unlock" position and remove the battery.
  2. HP Pavilion 15-ab165us Fan Replacement: adım 2, 3 resimden 1. HP Pavilion 15-ab165us Fan Replacement: adım 2, 3 resimden 2. HP Pavilion 15-ab165us Fan Replacement: adım 2, 3 resimden 3.
    • Remove the two 8mm screws underneath with a Phillips #1 screwdriver.
    • Use a plastic opening tool to remove the plastic feet.
  3. HP Pavilion 15-ab165us Fan Replacement: adım 3, 3 resimden 1. HP Pavilion 15-ab165us Fan Replacement: adım 3, 3 resimden 2. HP Pavilion 15-ab165us Fan Replacement: adım 3, 3 resimden 3.
    • Remove the two plastic tabs with a metal spudger.
  4. HP Pavilion 15-ab165us Fan Replacement: adım 4, 1 resimden 1.
    • Remove the sixteen 8mm screws that hold the bottom cover with a Phillips #1 screwdriver.
  5. HP Pavilion 15-ab165us Fan Replacement: adım 5, 1 resimden 1.
    • Pull the Optical Drive out.
  6. HP Pavilion 15-ab165us Fan Replacement: adım 6, 1 resimden 1.
    • Remove the 3mm screws that were hidden under the Optical Drive with a Phillips #0 screwdriver.
  7. HP Pavilion 15-ab165us Fan Replacement: adım 7, 2 resimden 1. HP Pavilion 15-ab165us Fan Replacement: adım 7, 2 resimden 2.
    • Flip the computer back over.
    • Use a plastic opening tool to release the clips holding the keyboard section in place.
  8. HP Pavilion 15-ab165us Fan Replacement: adım 8, 1 resimden 1.
    • Close the lid and pull the screen and keyboard section up and away from the disconnected bottom cover.
    • The hard drive is NOT screwed into place on the underside of the keyboard section.
  9. HP Pavilion 15-ab165us Fan Replacement, Fan: adım 9, 1 resimden 1.
    • Disconnect the fan from the motherboard.
  10. HP Pavilion 15-ab165us Fan Replacement: adım 10, 3 resimden 1. HP Pavilion 15-ab165us Fan Replacement: adım 10, 3 resimden 2. HP Pavilion 15-ab165us Fan Replacement: adım 10, 3 resimden 3.
    • Remove the the three 3mm screws with the Phillips#00 screwdriver.
  11. HP Pavilion 15-ab165us Fan Replacement: adım 11, 2 resimden 1. HP Pavilion 15-ab165us Fan Replacement: adım 11, 2 resimden 2.
    • Remove the fan from the motherboard.
Sonuç
Chad Christy
205 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S3-G1, Harley Fall 2019 IUPUI, Team S3-G1, Harley Fall 2019 üyesi
IUPUI-HARLEY-F19S3G1
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 602
