Giriş
This guide highlights the removal/replacement of the HP Pavilion 15-ab165us fan. The fan is a part used in electronics to dissipate heat out of the device. When the fan becomes damaged or the device stays at high temperature levels, it is recommended to replace the fan.
Neye ihtiyacın var
Flip the computer over so that the bottom cover is facing you.
Slide the two locks to the "unlock" position and remove the battery.
Neredeyse bitti!
Sonuç
