Ana içeriğe geç
HP Pavilion 15-ab165us Motherboard Replacement
Neye ihtiyacın var
  1. HP Pavilion 15-ab165us Motherboard Replacement, Battery and Back Cover: adım 1, 2 resimden 1. HP Pavilion 15-ab165us Motherboard Replacement, Battery and Back Cover: adım 1, 2 resimden 2.
    • Flip the computer over so that the bottom cover is facing you.
    • Slide the two locks to the "unlock" position and remove the battery.
  2. HP Pavilion 15-ab165us Motherboard Replacement: adım 2, 3 resimden 1. HP Pavilion 15-ab165us Motherboard Replacement: adım 2, 3 resimden 2. HP Pavilion 15-ab165us Motherboard Replacement: adım 2, 3 resimden 3.
    • Remove the two 8mm screws underneath with a Phillips #1 screwdriver.
    • Use a plastic opening tool to remove the plastic feet.
  3. HP Pavilion 15-ab165us Motherboard Replacement: adım 3, 3 resimden 1. HP Pavilion 15-ab165us Motherboard Replacement: adım 3, 3 resimden 2. HP Pavilion 15-ab165us Motherboard Replacement: adım 3, 3 resimden 3.
    • Remove the two plastic tabs with a metal spudger.
  4. HP Pavilion 15-ab165us Motherboard Replacement: adım 4, 1 resimden 1.
    • Remove the sixteen 8mm screws that hold the bottom cover with a Phillips #1 screwdriver.
  5. HP Pavilion 15-ab165us Motherboard Replacement: adım 5, 1 resimden 1.
    • Pull the Optical Drive out.
  6. HP Pavilion 15-ab165us Motherboard Replacement: adım 6, 1 resimden 1.
    • Remove the 3mm screws that were hidden under the Optical Drive with a Phillips #0 screwdriver.
  7. HP Pavilion 15-ab165us Motherboard Replacement: adım 7, 2 resimden 1. HP Pavilion 15-ab165us Motherboard Replacement: adım 7, 2 resimden 2.
    • Flip the computer back over.
    • Use a plastic opening tool to release the clips holding the keyboard section in place.
  8. HP Pavilion 15-ab165us Motherboard Replacement: adım 8, 1 resimden 1.
    • Close the lid and pull the screen and keyboard section up and away from the disconnected bottom cover.
    • The hard drive is NOT screwed into place on the underside of the keyboard section.
  9. HP Pavilion 15-ab165us Motherboard Replacement, Motherboard: adım 9, 1 resimden 1.
    • Locate the motherboard.
  10. HP Pavilion 15-ab165us Motherboard Replacement: adım 10, 2 resimden 1. HP Pavilion 15-ab165us Motherboard Replacement: adım 10, 2 resimden 2.
    • Disconnect the wire connected to the Wifi card.
  11. HP Pavilion 15-ab165us Motherboard Replacement: adım 11, 1 resimden 1.
    • Disconnect the speakers.
  12. HP Pavilion 15-ab165us Motherboard Replacement: adım 12, 3 resimden 1. HP Pavilion 15-ab165us Motherboard Replacement: adım 12, 3 resimden 2. HP Pavilion 15-ab165us Motherboard Replacement: adım 12, 3 resimden 3.
    • Unlock and disconnect cables attached to the motherboard that connect to the display.
  13. HP Pavilion 15-ab165us Motherboard Replacement: adım 13, 2 resimden 1. HP Pavilion 15-ab165us Motherboard Replacement: adım 13, 2 resimden 2.
    • Unlock and remove the cable connected to the optical drive.
  14. HP Pavilion 15-ab165us Motherboard Replacement: adım 14, 2 resimden 1. HP Pavilion 15-ab165us Motherboard Replacement: adım 14, 2 resimden 2.
    • Unlock and remove the cable that connects to the hard drive.
  15. HP Pavilion 15-ab165us Motherboard Replacement: adım 15, 3 resimden 1. HP Pavilion 15-ab165us Motherboard Replacement: adım 15, 3 resimden 2. HP Pavilion 15-ab165us Motherboard Replacement: adım 15, 3 resimden 3.
    • Unlock and remove the cables connected to the keyboard.
  16. HP Pavilion 15-ab165us Motherboard Replacement: adım 16, 1 resimden 1.
    • Remove the 4mm screws holding the motherboard in place with a Phillips #1 screwdriver.
  17. HP Pavilion 15-ab165us Motherboard Replacement: adım 17, 1 resimden 1.
  18. HP Pavilion 15-ab165us Motherboard Replacement: adım 18, 2 resimden 1. HP Pavilion 15-ab165us Motherboard Replacement: adım 18, 2 resimden 2.
    • Disconnect the fan pins.
    • Lift up to remove the fan.
  19. HP Pavilion 15-ab165us Motherboard Replacement: adım 19, 1 resimden 1.
    • Release motherboard from the clip at the base of the hard drive.
  20. HP Pavilion 15-ab165us Motherboard Replacement: adım 20, 2 resimden 1. HP Pavilion 15-ab165us Motherboard Replacement: adım 20, 2 resimden 2.
    • Lift the motherboard up and flip it around to reveal the cable connected on the underside.
  21. HP Pavilion 15-ab165us Motherboard Replacement: adım 21, 2 resimden 1. HP Pavilion 15-ab165us Motherboard Replacement: adım 21, 2 resimden 2.
    • Unlock and disconnect the cable connected to the underside of the motherboard.
    • Pull the motherboard out of the chassis.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Dillon Hubble
653 İtibar
3 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G2, Rose Fall 2017 UW Tacoma, Team S1-G2, Rose Fall 2017 üyesi
UWT-ROSE-F17S1G2
5 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 1,534
