Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
If you need to access internal components on your laptop, it is necessary to remove the case of the laptop. This guide will show you all the steps involved in the removal of the case.
Neye ihtiyacın var
Slide the battery lock tab toward the center of the battery to the unlock position.
With the battery removed, remove both black plastic covers with a plastic opening tool. Unscrew both 7.5 mm screws from the tabs, using a PH1 screw driver. Using a plastic opening tool, pry off both covers.
2 farklı kişi bu kılavuzu tamamladı.
