Ana içeriğe geç
Giriş
This guide will show you how to access the cooling fan and replace it. The cooling fan is necessary to keep your laptop from overheating.
  1. Slide the battery lock tab toward the center of the battery to the unlock position. Slide the battery lock tab toward the center of the battery to the unlock position.
    • Slide the battery lock tab toward the center of the battery to the unlock position.
  2. Slide the battery release switch to the right until the battery pops out. Slide the battery release switch to the right until the battery pops out. Slide the battery release switch to the right until the battery pops out.
    • Slide the battery release switch to the right until the battery pops out.
  3. Grabbing the top edge of the battery, rotate it toward you and then lift upward to relieve the battery from its slot. Grabbing the top edge of the battery, rotate it toward you and then lift upward to relieve the battery from its slot.
    • Grabbing the top edge of the battery, rotate it toward you and then lift upward to relieve the battery from its slot.
  4. With the battery removed, remove both black plastic covers with a plastic opening tool. Unscrew both 7.5 mm screws from the tabs, using a PH1 screw driver.  Using a plastic opening tool, pry off both covers. With the battery removed, remove both black plastic covers with a plastic opening tool. Unscrew both 7.5 mm screws from the tabs, using a PH1 screw driver.  Using a plastic opening tool, pry off both covers. With the battery removed, remove both black plastic covers with a plastic opening tool. Unscrew both 7.5 mm screws from the tabs, using a PH1 screw driver.  Using a plastic opening tool, pry off both covers.
    • With the battery removed, remove both black plastic covers with a plastic opening tool. Unscrew both 7.5 mm screws from the tabs, using a PH1 screw driver. Using a plastic opening tool, pry off both covers.
  5. Remove all 16 of the 3.5 mm screws with a PH1 screwdriver and pry/slide the CD drive out of laptop. Remove all 16 of the 3.5 mm screws with a PH1 screwdriver and pry/slide the CD drive out of laptop. Remove all 16 of the 3.5 mm screws with a PH1 screwdriver and pry/slide the CD drive out of laptop.
    • Remove all 16 of the 3.5 mm screws with a PH1 screwdriver and pry/slide the CD drive out of laptop.
  6. With the CD drive removed, unscrew the two 2mm silver screws with a PH00. These can strip easily, so take your time removing.
    • With the CD drive removed, unscrew the two 2mm silver screws with a PH00.
    • These can strip easily, so take your time removing.
  7. Using a plastic opening tool, begin to pry edge of case away from the laptop. Work around the edges until all sides, except back, are open. Using a plastic opening tool, begin to pry edge of case away from the laptop. Work around the edges until all sides, except back, are open. Using a plastic opening tool, begin to pry edge of case away from the laptop. Work around the edges until all sides, except back, are open.
    • Using a plastic opening tool, begin to pry edge of case away from the laptop. Work around the edges until all sides, except back, are open.
  8. On the back side of the laptop, where the battery is, there are 12 black plastic clips. Use a plastic opening tool and pry all of these clips, unlatching them from the case. Once clips are free, open the laptop. Rotating the case off, around the hinges, works best to remove the case. Once clips are free, open the laptop. Rotating the case off, around the hinges, works best to remove the case.
    • On the back side of the laptop, where the battery is, there are 12 black plastic clips. Use a plastic opening tool and pry all of these clips, unlatching them from the case.
    • Once clips are free, open the laptop. Rotating the case off, around the hinges, works best to remove the case.
  9. Use a PH00 screw driver to remove the two 3.5 mm screws holding the fan in place. Careful with the lower screw, there are two screws side by side. The screw to the left side of the device is the one you want and is connected to fan, the one on the right side is not for fan. Careful with the lower screw, there are two screws side by side. The screw to the left side of the device is the one you want and is connected to fan, the one on the right side is not for fan.
    • Use a PH00 screw driver to remove the two 3.5 mm screws holding the fan in place.
    • Careful with the lower screw, there are two screws side by side. The screw to the left side of the device is the one you want and is connected to fan, the one on the right side is not for fan.
  10. Use long nose tweezers to remove connector. Fan will lift out. Use long nose tweezers to remove connector. Fan will lift out. Use long nose tweezers to remove connector. Fan will lift out.
    • Use long nose tweezers to remove connector. Fan will lift out.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alexander Bicigo
864 İtibar
6 adet Kılavuz yazıldı
Takım
USF Tampa, Team S6-G3, Eyestone Spring 2018 USF Tampa, Team S6-G3, Eyestone Spring 2018 üyesi
USFT-EYESTONE-S18S6G3
3 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 Gün: 8
Son 30 Gün: 24
Her zaman: 428
