Ana içeriğe geç
HP Pavilion 15-ab243cl RAM Stick Replacement
Neye ihtiyacın var
  1. HP Pavilion 15-ab243cl RAM Stick Replacement, Battery: adım 1, 2 resimden 1. HP Pavilion 15-ab243cl RAM Stick Replacement, Battery: adım 1, 2 resimden 2.
    • Slide the battery lock tab toward the center of the battery to the unlock position.
  2. HP Pavilion 15-ab243cl RAM Stick Replacement: adım 2, 3 resimden 1. HP Pavilion 15-ab243cl RAM Stick Replacement: adım 2, 3 resimden 2. HP Pavilion 15-ab243cl RAM Stick Replacement: adım 2, 3 resimden 3.
    • Slide the battery release switch to the right until the battery pops out.
  3. HP Pavilion 15-ab243cl RAM Stick Replacement: adım 3, 2 resimden 1. HP Pavilion 15-ab243cl RAM Stick Replacement: adım 3, 2 resimden 2.
    • Grabbing the top edge of the battery, rotate it toward you and then lift upward to relieve the battery from its slot.
  4. HP Pavilion 15-ab243cl RAM Stick Replacement, Laptop Case: adım 4, 3 resimden 1. HP Pavilion 15-ab243cl RAM Stick Replacement, Laptop Case: adım 4, 3 resimden 2. HP Pavilion 15-ab243cl RAM Stick Replacement, Laptop Case: adım 4, 3 resimden 3.
    • With the battery removed, remove both black plastic covers with a plastic opening tool. Unscrew both 7.5 mm screws from the tabs, using a PH1 screw driver. Using a plastic opening tool, pry off both covers.
  5. HP Pavilion 15-ab243cl RAM Stick Replacement: adım 5, 3 resimden 1. HP Pavilion 15-ab243cl RAM Stick Replacement: adım 5, 3 resimden 2. HP Pavilion 15-ab243cl RAM Stick Replacement: adım 5, 3 resimden 3.
    • Remove all 16 of the 3.5 mm screws with a PH1 screwdriver and pry/slide the CD drive out of laptop.
  6. HP Pavilion 15-ab243cl RAM Stick Replacement: adım 6, 2 resimden 1. HP Pavilion 15-ab243cl RAM Stick Replacement: adım 6, 2 resimden 2.
    • With the CD drive removed, unscrew the two 2mm silver screws with a PH00.
    • These can strip easily, so take your time removing.
  7. HP Pavilion 15-ab243cl RAM Stick Replacement: adım 7, 3 resimden 1. HP Pavilion 15-ab243cl RAM Stick Replacement: adım 7, 3 resimden 2. HP Pavilion 15-ab243cl RAM Stick Replacement: adım 7, 3 resimden 3.
    • Using a plastic opening tool, begin to pry edge of case away from the laptop. Work around the edges until all sides, except back, are open.
  8. HP Pavilion 15-ab243cl RAM Stick Replacement: adım 8, 3 resimden 1. HP Pavilion 15-ab243cl RAM Stick Replacement: adım 8, 3 resimden 2. HP Pavilion 15-ab243cl RAM Stick Replacement: adım 8, 3 resimden 3.
    • On the back side of the laptop, where the battery is, there are 12 black plastic clips. Use a plastic opening tool and pry all of these clips, unlatching them from the case.
    • Once clips are free, open the laptop. Rotating the case off, around the hinges, works best to remove the case.
  9. HP Pavilion 15-ab243cl RAM Stick Replacement, RAM Stick: adım 9, 3 resimden 1. HP Pavilion 15-ab243cl RAM Stick Replacement, RAM Stick: adım 9, 3 resimden 2. HP Pavilion 15-ab243cl RAM Stick Replacement, RAM Stick: adım 9, 3 resimden 3.
    • Locate the RAM stick, will be next to hard drive. Unclip the two silver retainers on each side.
  10. HP Pavilion 15-ab243cl RAM Stick Replacement: adım 10, 2 resimden 1. HP Pavilion 15-ab243cl RAM Stick Replacement: adım 10, 2 resimden 2.
    • The card will pop up when silver retainers are released. The card is ready to remove, pull straight out.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alexander Bicigo
942 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S6-G3, Eyestone Spring 2018 USF Tampa, Team S6-G3, Eyestone Spring 2018 üyesi
USFT-EYESTONE-S18S6G3
3 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 26
Her zaman: 671
