Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
This guide will show you how to access your RAM and replace/upgrade the RAM. There are two slots allowing for an easy RAM expansion upgrade. The replacement of the current RAM is covered in this guide.
Neye ihtiyacın var
Slide the battery lock tab toward the center of the battery to the unlock position.
With the battery removed, remove both black plastic covers with a plastic opening tool. Unscrew both 7.5 mm screws from the tabs, using a PH1 screw driver. Using a plastic opening tool, pry off both covers.
Locate the RAM stick, will be next to hard drive. Unclip the two silver retainers on each side.
Bir başkası bu kılavuzu tamamladı.
