Ana içeriğe geç
HP Pavilion 15-au123cl Battery Replacement
Neye ihtiyacın var
Videoya Genel Bakış
    1. HP Pavilion 15-au123cl Battery Replacement, Battery: adım 1, 1 resimden 1.
      • Make sure the laptop is off and unplugged before starting.
      • Using the plastic opening tool, remove the top rubber feet on the back panel as it hides one of the screws we will be removing.
      FixBot'a Sor
      Yorum Ekle
    2. HP Pavilion 15-au123cl Battery Replacement: adım 2, 2 resimden 1. HP Pavilion 15-au123cl Battery Replacement: adım 2, 2 resimden 2.
      • Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel.
      FixBot'a Sor
      Yorum Ekle
    3. HP Pavilion 15-au123cl Battery Replacement: adım 3, 2 resimden 1. HP Pavilion 15-au123cl Battery Replacement: adım 3, 2 resimden 2.
      • Using the plastic opening tool, remove the back cover of the laptop.
      • It is recommended that you start with a corner and run the tool throughout the edges of the cover.
      • Be sure not to bend the cover by applying too much force.
      FixBot'a Sor
      Yorum Ekle
    4. HP Pavilion 15-au123cl Battery Replacement: adım 4, 2 resimden 1. HP Pavilion 15-au123cl Battery Replacement: adım 4, 2 resimden 2.
      • Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place.
      FixBot'a Sor
      Yorum Ekle
    5. HP Pavilion 15-au123cl Battery Replacement: adım 5, 3 resimden 1. HP Pavilion 15-au123cl Battery Replacement: adım 5, 3 resimden 2. HP Pavilion 15-au123cl Battery Replacement: adım 5, 3 resimden 3.
      • Carefully disconnect the cable connecting the top of the battery and remove the battery.
      FixBot'a Sor
      Yorum Ekle
Sonuç
18 farklı kişi bu kılavuzu tamamladı.
Mohammad Gardezi
1.420 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S13-G3, Cagle Fall 2017 USF Tampa, Team S13-G3, Cagle Fall 2017 üyesi
USFT-CAGLE-F17S13G3
2 Üyeler
72 adet Kılavuz yazıldı
6Kılavuz Yorumları
That one screw under the rubber pad is a special kind of BS.
Liam Kosloski - Yanıt Paylaş
The screw in the middle of everything was hardest for me to reinstall because it has to hold the CD drive in place ,and that drive hole must line up with everything else _just right_. Also, prying the keyboard from the shell was harder than I expected. It’s snapped in there pretty tight.
kctipton - Yanıt Paylaş
The procedure should be modified to start with removing the center screw that retains the DVD drive and then pulling out the drive. That makes separating the case halves easier.
George Mells - Yanıt Paylaş
My problem on ebay and amazon i only got aftermarket battery they claim oem 849909-850
I BOUGHT 3 SO FAR SAME THING …HP SAYS THEY DONT HAVE THE BATTERY FOR SALE ANY LONGER
Laptop wont start with nee battery … i conect old one with power on , once start conect new one and works
When shutdown or sleep it wont start with new battery
Will restart with new battery and last up to 6 hours new battery but wont start.
How can i start my laptop with new battery ?
Juan Carlos Gomez - Yanıt Paylaş
It would be useful to have a heads up on how to get the CD/DVD drive back in place. I found ejecting the CD tray before shutdown and disassembly gave me some wiggle room when reinstalling. Then, you have to slide the CD plug into the motherboard jack before snapping the back cover into place. Make sure the screw hole on the CD drive aligns properly with the screw hole on the motherboard.
Also, my battery had 3 screws; one at the "top," one at each bottom corner.
John Darago - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 38
Her zaman: 25,307
