Ana içeriğe geç
HP Pavilion 15-au123cl CMOS Battery Replacement
Neye ihtiyacın var
  1. HP Pavilion 15-au123cl CMOS Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure the laptop is off and unplugged before starting.
    • Using the plastic opening tool, remove the top rubber feet on the back panel as it hides one of the screws we will be removing.
  2. HP Pavilion 15-au123cl CMOS Battery Replacement: adım 2, 2 resimden 1. HP Pavilion 15-au123cl CMOS Battery Replacement: adım 2, 2 resimden 2.
    • Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel.
  3. HP Pavilion 15-au123cl CMOS Battery Replacement: adım 3, 2 resimden 1. HP Pavilion 15-au123cl CMOS Battery Replacement: adım 3, 2 resimden 2.
    • Using the plastic opening tool, remove the back cover of the laptop.
    • It is recommended that you start with a corner and run the tool throughout the edges of the cover.
    • Be sure not to bend the cover by applying too much force.
  4. HP Pavilion 15-au123cl CMOS Battery Replacement: adım 4, 2 resimden 1. HP Pavilion 15-au123cl CMOS Battery Replacement: adım 4, 2 resimden 2.
    • Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place.
  5. HP Pavilion 15-au123cl CMOS Battery Replacement: adım 5, 3 resimden 1. HP Pavilion 15-au123cl CMOS Battery Replacement: adım 5, 3 resimden 2. HP Pavilion 15-au123cl CMOS Battery Replacement: adım 5, 3 resimden 3.
    • Carefully disconnect the cable connecting the top of the battery and remove the battery.
  6. HP Pavilion 15-au123cl CMOS Battery Replacement, CMOS Battery: adım 6, 2 resimden 1. HP Pavilion 15-au123cl CMOS Battery Replacement, CMOS Battery: adım 6, 2 resimden 2.
    • The CMOS battery is located toward the middle left area of the motherboard.
    • Using the spudger, lift the CMOS battery out of its plastic casing.
  7. HP Pavilion 15-au123cl CMOS Battery Replacement: adım 7, 1 resimden 1.
    • Fully remove the CMOS battery from the motherboard.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Mohammad Gardezi
1.420 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S13-G3, Cagle Fall 2017 USF Tampa, Team S13-G3, Cagle Fall 2017 üyesi
USFT-CAGLE-F17S13G3
2 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 35
Son 30 gün: 196
Her zaman: 26,016
