Ana içeriğe geç
HP Pavilion 15-au123cl CMOS Battery Replacement
Neye ihtiyacın var
    1. HP Pavilion 15-au123cl CMOS Battery Replacement, Battery: adım 1, 1 resimden 1.
      • Make sure the laptop is off and unplugged before starting.
      • Using the plastic opening tool, remove the top rubber feet on the back panel as it hides one of the screws we will be removing.
      FixBot'a Sor
      Yorum Ekle
    2. HP Pavilion 15-au123cl CMOS Battery Replacement: adım 2, 2 resimden 1. HP Pavilion 15-au123cl CMOS Battery Replacement: adım 2, 2 resimden 2.
      • Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel.
      FixBot'a Sor
      Yorum Ekle
    3. HP Pavilion 15-au123cl CMOS Battery Replacement: adım 3, 2 resimden 1. HP Pavilion 15-au123cl CMOS Battery Replacement: adım 3, 2 resimden 2.
      • Using the plastic opening tool, remove the back cover of the laptop.
      • It is recommended that you start with a corner and run the tool throughout the edges of the cover.
      • Be sure not to bend the cover by applying too much force.
      FixBot'a Sor
      Yorum Ekle
    4. HP Pavilion 15-au123cl CMOS Battery Replacement: adım 4, 2 resimden 1. HP Pavilion 15-au123cl CMOS Battery Replacement: adım 4, 2 resimden 2.
      • Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place.
      FixBot'a Sor
      Yorum Ekle
    5. HP Pavilion 15-au123cl CMOS Battery Replacement: adım 5, 3 resimden 1. HP Pavilion 15-au123cl CMOS Battery Replacement: adım 5, 3 resimden 2. HP Pavilion 15-au123cl CMOS Battery Replacement: adım 5, 3 resimden 3.
      • Carefully disconnect the cable connecting the top of the battery and remove the battery.
      FixBot'a Sor
      Yorum Ekle
    1. HP Pavilion 15-au123cl CMOS Battery Replacement, CMOS Battery: adım 6, 2 resimden 1. HP Pavilion 15-au123cl CMOS Battery Replacement, CMOS Battery: adım 6, 2 resimden 2.
      • The CMOS battery is located toward the middle left area of the motherboard.
      • Using the spudger, lift the CMOS battery out of its plastic casing.
      FixBot'a Sor
      Yorum Ekle
    2. HP Pavilion 15-au123cl CMOS Battery Replacement: adım 7, 1 resimden 1.
      • Fully remove the CMOS battery from the motherboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Mohammad Gardezi
1.420 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S13-G3, Cagle Fall 2017 USF Tampa, Team S13-G3, Cagle Fall 2017 üyesi
USFT-CAGLE-F17S13G3
2 Üyeler
54 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 42
Son 30 gün: 132
Her zaman: 28,979
