Ana içeriğe geç
HP Pavilion 15-au123cl Hard Drive Replacement
Neye ihtiyacın var
  1. HP Pavilion 15-au123cl Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure the laptop is off and unplugged before starting.
    • Using the plastic opening tool, remove the top rubber feet on the back panel as it hides one of the screws we will be removing.
  2. HP Pavilion 15-au123cl Hard Drive Replacement: adım 2, 2 resimden 1. HP Pavilion 15-au123cl Hard Drive Replacement: adım 2, 2 resimden 2.
    • Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel.
    Correction. Top two screen pivot screws are bigger than the 8, 4mm.
    Mitchell Culp II - Yanıt
  3. HP Pavilion 15-au123cl Hard Drive Replacement: adım 3, 2 resimden 1. HP Pavilion 15-au123cl Hard Drive Replacement: adım 3, 2 resimden 2.
    • Using the plastic opening tool, remove the back cover of the laptop.
    • It is recommended that you start with a corner and run the tool throughout the edges of the cover.
    • Be sure not to bend the cover by applying too much force.
    What? I think you have have neglected to mention the DVD drawer. I believe it needs to be pulled out after removing the center screw and before removing the cover.
    Dan Enslow - Yanıt
    Yes, best to remove the drawer as recommended. Also there are 3 screws holding the battery, not 2.
    Lastly, pay careful attention to the orientation photo when removing the back.
    I did not have the plastic tool but used a small Teflon type kitchen spatula and it did the trick. Do not use a metal screw driver or other such tool.
    Edward Yandek - Yanıt
  4. HP Pavilion 15-au123cl Hard Drive Replacement: adım 4, 2 resimden 1. HP Pavilion 15-au123cl Hard Drive Replacement: adım 4, 2 resimden 2.
    • Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place.
    there is a third screw on bottom left of battery (in picture above)
    Paul Behrman - Yanıt
  5. HP Pavilion 15-au123cl Hard Drive Replacement: adım 5, 3 resimden 1. HP Pavilion 15-au123cl Hard Drive Replacement: adım 5, 3 resimden 2. HP Pavilion 15-au123cl Hard Drive Replacement: adım 5, 3 resimden 3.
    • Carefully disconnect the cable connecting the top of the battery and remove the battery.
  6. HP Pavilion 15-au123cl Hard Drive Replacement, Hard Drive: adım 6, 3 resimden 1. HP Pavilion 15-au123cl Hard Drive Replacement, Hard Drive: adım 6, 3 resimden 2. HP Pavilion 15-au123cl Hard Drive Replacement, Hard Drive: adım 6, 3 resimden 3.
    • The hard drive is located at the lower left area of the motherboard.
    • Using the spudger, lift the white latch holding the hard drive cable in place.
  7. HP Pavilion 15-au123cl Hard Drive Replacement: adım 7, 1 resimden 1.
    • Using the opening tool, lift the hard drive out of the motherboard.
  8. HP Pavilion 15-au123cl Hard Drive Replacement: adım 8, 2 resimden 1. HP Pavilion 15-au123cl Hard Drive Replacement: adım 8, 2 resimden 2.
    • Remove the hard drive cable from the hard drive.
  9. HP Pavilion 15-au123cl Hard Drive Replacement: adım 9, 2 resimden 1. HP Pavilion 15-au123cl Hard Drive Replacement: adım 9, 2 resimden 2.
    • Pull off the plastic wedges on both sides of the hard drive.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Mohammad Gardezi
1.420 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S13-G3, Cagle Fall 2017 USF Tampa, Team S13-G3, Cagle Fall 2017 üyesi
USFT-CAGLE-F17S13G3
2 Üyeler
Bir Yorum
The latch on mine was black, and the socket on the m/b was white. Guess who ruined his m/b following these instructions?
TJ Fitzgerald - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 18
Son 30 gün: 78
Her zaman: 6,999
