Ana içeriğe geç
HP Pavilion 15-au123cl Motherboard Replacement
Neye ihtiyacın var
  1. HP Pavilion 15-au123cl Motherboard Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure the laptop is off and unplugged before starting.
    • Using the plastic opening tool, remove the top rubber feet on the back panel as it hides one of the screws we will be removing.
  2. HP Pavilion 15-au123cl Motherboard Replacement: adım 2, 2 resimden 1. HP Pavilion 15-au123cl Motherboard Replacement: adım 2, 2 resimden 2.
    • Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel.
  3. HP Pavilion 15-au123cl Motherboard Replacement: adım 3, 2 resimden 1. HP Pavilion 15-au123cl Motherboard Replacement: adım 3, 2 resimden 2.
    • Using the plastic opening tool, remove the back cover of the laptop.
    • It is recommended that you start with a corner and run the tool throughout the edges of the cover.
    • Be sure not to bend the cover by applying too much force.
  4. HP Pavilion 15-au123cl Motherboard Replacement: adım 4, 2 resimden 1. HP Pavilion 15-au123cl Motherboard Replacement: adım 4, 2 resimden 2.
    • Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place.
  5. HP Pavilion 15-au123cl Motherboard Replacement: adım 5, 3 resimden 1. HP Pavilion 15-au123cl Motherboard Replacement: adım 5, 3 resimden 2. HP Pavilion 15-au123cl Motherboard Replacement: adım 5, 3 resimden 3.
    • Carefully disconnect the cable connecting the top of the battery and remove the battery.
  6. HP Pavilion 15-au123cl Motherboard Replacement, Network Card: adım 6, 3 resimden 1. HP Pavilion 15-au123cl Motherboard Replacement, Network Card: adım 6, 3 resimden 2. HP Pavilion 15-au123cl Motherboard Replacement, Network Card: adım 6, 3 resimden 3.
    • The network card is located at the top left corner of the motherboard.
    • Unscrew the 4.4mm PH0 Phillips screw at the top of the network card.
  7. HP Pavilion 15-au123cl Motherboard Replacement: adım 7, 3 resimden 1. HP Pavilion 15-au123cl Motherboard Replacement: adım 7, 3 resimden 2. HP Pavilion 15-au123cl Motherboard Replacement: adım 7, 3 resimden 3.
    • Using the spudger, remove the two gold pins at the top of the network card.
    • It is recommended to gently apply a vertical force upward with the spudger.
  8. HP Pavilion 15-au123cl Motherboard Replacement: adım 8, 3 resimden 1. HP Pavilion 15-au123cl Motherboard Replacement: adım 8, 3 resimden 2. HP Pavilion 15-au123cl Motherboard Replacement: adım 8, 3 resimden 3.
    • Lift up the network card and remove it from the motherboard connector.
  9. HP Pavilion 15-au123cl Motherboard Replacement, Motherboard: adım 9, 1 resimden 1.
    • Firmly disconnect the fan from the motherboard.
    • Remove the three screws from the fan using a Philips #0 Screwdriver.
  10. HP Pavilion 15-au123cl Motherboard Replacement: adım 10, 1 resimden 1.
    • Remove the six screws from the motherboard using a Philips #0 Screwdriver.
  11. HP Pavilion 15-au123cl Motherboard Replacement: adım 11, 1 resimden 1.
    • Disconnect the ribbon cables from the motherboard.
    • Remove the motherboard.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
buenas tardes : Nesecito saber donde puedo conseguir el Motherboard para una HP Pavilion Y1N95UA 15-AU123CL descrito en este posteo ..
Saludos Gabriel Angel..!!!
Gabriel Antonielli - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 22
Her zaman: 1,950
