Giriş
Using this guide, you should be able to replace the network card on your laptop. If you are having internet connectivity issues, this guide could be your best bet for fixing them. Do note that when replacing the part, make sure the gold connection pins are fully connected when putting the network card in place.
Neye ihtiyacın var
Using the plastic opening tool, remove the top rubber feet on the back panel as it hides one of the screws we will be removing.
The network card is located at the top left corner of the motherboard.
Unscrew the 4.4mm PH0 Phillips screw at the top of the network card.
