Ana içeriğe geç
HP Pavilion 15-ay041wm Keyboard Replacement
Neye ihtiyacın var
  1. HP Pavilion 15-ay041wm Keyboard Replacement, Battery: adım 1, 2 resimden 1. HP Pavilion 15-ay041wm Keyboard Replacement, Battery: adım 1, 2 resimden 2.
    • Place the laptop upside down.
  2. HP Pavilion 15-ay041wm Keyboard Replacement: adım 2, 2 resimden 1. HP Pavilion 15-ay041wm Keyboard Replacement: adım 2, 2 resimden 2.
    • Find the battery lock latch on the top left corner.
    • Slide the latch to the right position.
  3. HP Pavilion 15-ay041wm Keyboard Replacement: adım 3, 3 resimden 1. HP Pavilion 15-ay041wm Keyboard Replacement: adım 3, 3 resimden 2. HP Pavilion 15-ay041wm Keyboard Replacement: adım 3, 3 resimden 3.
    • Find the battery release latch on the top right corner.
    • Slide and hold the latch towards the left to cover the battery icon.
    • Carefully slide the battery outwards.
  4. HP Pavilion 15-ay041wm Keyboard Replacement, Disc Drive: adım 4, 1 resimden 1.
    • Turn the laptop upside down with the base of the laptop facing you.
    • Remove the grippers positioned at the top right and top left of the laptop to access the two additional screws.
    • Use a 1.5mm Hex screwdriver to remove twelve 10mm screws.
  5. HP Pavilion 15-ay041wm Keyboard Replacement: adım 5, 3 resimden 1. HP Pavilion 15-ay041wm Keyboard Replacement: adım 5, 3 resimden 2. HP Pavilion 15-ay041wm Keyboard Replacement: adım 5, 3 resimden 3.
    • Press the eject button.
    • Hold and carefully slide the disc drive out of the laptop.
  6. HP Pavilion 15-ay041wm Keyboard Replacement, Keyboard: adım 6, 3 resimden 1. HP Pavilion 15-ay041wm Keyboard Replacement, Keyboard: adım 6, 3 resimden 2. HP Pavilion 15-ay041wm Keyboard Replacement, Keyboard: adım 6, 3 resimden 3.
    • Using the Jimmy, create a separation between the keyboard and bottom panel.
    • Slide around the body of the panel until the separation is big enough for you to use your fingers.
    • Separate the keyboard and bottom panel.
Sonuç
Kristen Gismondi
92.282 İtibar
241 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.537 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 14
Son 30 gün: 33
Her zaman: 808
