Ana içeriğe geç
HP Pavilion 15-ay041wm Optical Disc Drive Replacement
Neye ihtiyacın var
  1. HP Pavilion 15-ay041wm Optical Disc Drive Replacement, Battery: adım 1, 2 resimden 1. HP Pavilion 15-ay041wm Optical Disc Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Place the laptop upside down.
  2. HP Pavilion 15-ay041wm Optical Disc Drive Replacement: adım 2, 2 resimden 1. HP Pavilion 15-ay041wm Optical Disc Drive Replacement: adım 2, 2 resimden 2.
    • Find the battery lock latch on the top left corner.
    • Slide the latch to the right position.
  3. HP Pavilion 15-ay041wm Optical Disc Drive Replacement: adım 3, 3 resimden 1. HP Pavilion 15-ay041wm Optical Disc Drive Replacement: adım 3, 3 resimden 2. HP Pavilion 15-ay041wm Optical Disc Drive Replacement: adım 3, 3 resimden 3.
    • Find the battery release latch on the top right corner.
    • Slide and hold the latch towards the left to cover the battery icon.
    • Carefully slide the battery outwards.
  4. HP Pavilion 15-ay041wm Optical Disc Drive Replacement, Disc Drive: adım 4, 1 resimden 1.
    • Turn the laptop upside down with the base of the laptop facing you.
    • Remove the grippers positioned at the top right and top left of the laptop to access the two additional screws.
    • Use a 1.5mm Hex screwdriver to remove twelve 10mm screws.
  5. HP Pavilion 15-ay041wm Optical Disc Drive Replacement: adım 5, 3 resimden 1. HP Pavilion 15-ay041wm Optical Disc Drive Replacement: adım 5, 3 resimden 2. HP Pavilion 15-ay041wm Optical Disc Drive Replacement: adım 5, 3 resimden 3.
    • Press the eject button.
    • Hold and carefully slide the disc drive out of the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kristen Gismondi
92.568 İtibar
241 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.632 adet Kılavuz yazıldı
1Rehber Yorum
Might add “Optical” to drive title to save some confusion.
mike - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 17
Son 30 gün: 37
Her zaman: 683
