Ana içeriğe geç
Giriş
If troubleshooting steps have been followed and it is obvious that the problem with the device might be originating from a faulty battery, then follow these steps to replace your device battery. Before starting to poke into the device, ensure to take safety precautions to avoid battery fluid getting on skin or any valuables. This replacement would take about 5 minutes. So, take your time and follow the steps thoroughly and this will be a success.
  1. Power off the device and disconnect from any power source.
    • Power off the device and disconnect from any power source.
  2. Turn the device upside down and ensure the back of the device is facing you.
    • Turn the device upside down and ensure the back of the device is facing you.
  3. MacBook Pil Tamir Setleri
    Başlangıç $69.99
    Buy Now
    Başlangıç $69.99
    Buy Now
  4. Push both buttons towards one another simultaneously. The battery slightly pops out. Push both buttons towards one another simultaneously. The battery slightly pops out. Push both buttons towards one another simultaneously. The battery slightly pops out.
    • Push both buttons towards one another simultaneously. The battery slightly pops out.
  5. Pull out the battery from the device's battery slot. Pull out the battery from the device's battery slot. Pull out the battery from the device's battery slot.
    • Pull out the battery from the device's battery slot.
Sonuç
David Atunlute
241 İtibar
2 adet Kılavuz yazıldı
Takım
UMass Dartmouth, Team S2-G2, Peak Fall 2018 UMass Dartmouth, Team S2-G2, Peak Fall 2018 üyesi
UMASSD-PEAK-F18S2G2
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 1
Son 30 Gün: 8
Her zaman: 100
