Ana içeriğe geç
HP Pavilion 15-b109wm Keyboard Replacement
Neye ihtiyacın var
  1. HP Pavilion 15-b109wm Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Power off the device and disconnect from any power source.
  2. HP Pavilion 15-b109wm Keyboard Replacement: adım 2, 1 resimden 1.
    • Turn the device upside down and ensure the back of the device is facing you.
  3. HP Pavilion 15-b109wm Keyboard Replacement: adım 3, 3 resimden 1. HP Pavilion 15-b109wm Keyboard Replacement: adım 3, 3 resimden 2. HP Pavilion 15-b109wm Keyboard Replacement: adım 3, 3 resimden 3.
    • Push both buttons towards one another simultaneously. The battery slightly pops out.
  4. HP Pavilion 15-b109wm Keyboard Replacement: adım 4, 3 resimden 1. HP Pavilion 15-b109wm Keyboard Replacement: adım 4, 3 resimden 2. HP Pavilion 15-b109wm Keyboard Replacement: adım 4, 3 resimden 3.
    • Pull out the battery from the device's battery slot.
  5. HP Pavilion 15-b109wm Keyboard Replacement, Keyboard: adım 5, 2 resimden 1. HP Pavilion 15-b109wm Keyboard Replacement, Keyboard: adım 5, 2 resimden 2.
    • Use JIS #1 screwdriver to remove the eleven 6 mm screws.
  6. HP Pavilion 15-b109wm Keyboard Replacement: adım 6, 1 resimden 1.
    • Locate the two screw holes that allow access to removing the keyboard.
    • There is a keyboard sign beside both keyboard access holes.
  7. HP Pavilion 15-b109wm Keyboard Replacement: adım 7, 1 resimden 1.
    • Turn the device onto its side.
    • Using a heavy duty spudger, gently disengage the keyboard.
  8. HP Pavilion 15-b109wm Keyboard Replacement: adım 8, 2 resimden 1. HP Pavilion 15-b109wm Keyboard Replacement: adım 8, 2 resimden 2.
    • Using a plastic opening tool, release the keyboard clips.
  9. HP Pavilion 15-b109wm Keyboard Replacement: adım 9, 1 resimden 1.
    • Tilt the keyboard to expose the Zero Insertion Force connector to which the keyboard cable is attached.
  10. HP Pavilion 15-b109wm Keyboard Replacement: adım 10, 3 resimden 1. HP Pavilion 15-b109wm Keyboard Replacement: adım 10, 3 resimden 2. HP Pavilion 15-b109wm Keyboard Replacement: adım 10, 3 resimden 3.
    • Disconnect the keyboard cable from the motherboard by detaching the Zero Insertion Force connector.
    • To detach the connector, release by lifting the black plastic tab up.
Sonuç
David Atunlute
241 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G2, Peak Fall 2018 UMass Dartmouth, Team S2-G2, Peak Fall 2018 üyesi
UMASSD-PEAK-F18S2G2
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 469
