Giriş
This replacement guide will show how to replace the Motherboard of an HP Pavilion 15-b109wm. This process will take between 25-35 minutes, if done correctly. Remember to take your time and do the steps correctly and gently to avoid parts breakage.
For this guide you will need a heavy-duty spudger, a JIS driver set and an iFixtit opening tool. Some parts of this guide require some force to pop open, be careful not to brake or damage any parts when applying force.
Neye ihtiyacın var
Unclip the WLAN cable out of its place to allow the motherboard room to move.
To reassemble your device work in the reverse order, make sure all the screws are in their required hole before assembling the next part.
