Ana içeriğe geç
HP Pavilion 15-b109wm WLAN Module Replacement
Neye ihtiyacın var
  1. HP Pavilion 15-b109wm WLAN Module Replacement, Battery: adım 1, 1 resimden 1.
    • Power off the device and disconnect from any power source.
  2. HP Pavilion 15-b109wm WLAN Module Replacement: adım 2, 1 resimden 1.
    • Turn the device upside down and ensure the back of the device is facing you.
  3. HP Pavilion 15-b109wm WLAN Module Replacement: adım 3, 3 resimden 1. HP Pavilion 15-b109wm WLAN Module Replacement: adım 3, 3 resimden 2. HP Pavilion 15-b109wm WLAN Module Replacement: adım 3, 3 resimden 3.
    • Push both buttons towards one another simultaneously. The battery slightly pops out.
  4. HP Pavilion 15-b109wm WLAN Module Replacement: adım 4, 3 resimden 1. HP Pavilion 15-b109wm WLAN Module Replacement: adım 4, 3 resimden 2. HP Pavilion 15-b109wm WLAN Module Replacement: adım 4, 3 resimden 3.
    • Pull out the battery from the device's battery slot.
  5. HP Pavilion 15-b109wm WLAN Module Replacement, Keyboard: adım 5, 2 resimden 1. HP Pavilion 15-b109wm WLAN Module Replacement, Keyboard: adım 5, 2 resimden 2.
    • Use JIS #1 screwdriver to remove the eleven 6 mm screws.
  6. HP Pavilion 15-b109wm WLAN Module Replacement: adım 6, 1 resimden 1.
    • Locate the two screw holes that allow access to removing the keyboard.
    • There is a keyboard sign beside both keyboard access holes.
  7. HP Pavilion 15-b109wm WLAN Module Replacement: adım 7, 1 resimden 1.
    • Turn the device onto its side.
    • Using a heavy duty spudger, gently disengage the keyboard.
  8. HP Pavilion 15-b109wm WLAN Module Replacement: adım 8, 2 resimden 1. HP Pavilion 15-b109wm WLAN Module Replacement: adım 8, 2 resimden 2.
    • Using a plastic opening tool, release the keyboard clips.
  9. HP Pavilion 15-b109wm WLAN Module Replacement: adım 9, 1 resimden 1.
    • Tilt the keyboard to expose the Zero Insertion Force connector to which the keyboard cable is attached.
  10. HP Pavilion 15-b109wm WLAN Module Replacement: adım 10, 3 resimden 1. HP Pavilion 15-b109wm WLAN Module Replacement: adım 10, 3 resimden 2. HP Pavilion 15-b109wm WLAN Module Replacement: adım 10, 3 resimden 3.
    • Disconnect the keyboard cable from the motherboard by detaching the Zero Insertion Force connector.
    • To detach the connector, release by lifting the black plastic tab up.
  11. HP Pavilion 15-b109wm WLAN Module Replacement, Fan: adım 11, 3 resimden 1. HP Pavilion 15-b109wm WLAN Module Replacement, Fan: adım 11, 3 resimden 2. HP Pavilion 15-b109wm WLAN Module Replacement, Fan: adım 11, 3 resimden 3.
    • Using a JIS #1 screwdriver, remove the five 5mm screws.
    • Detach the power button cable.
    • Detach the touch pad cable.
  12. HP Pavilion 15-b109wm WLAN Module Replacement: adım 12, 3 resimden 1. HP Pavilion 15-b109wm WLAN Module Replacement: adım 12, 3 resimden 2. HP Pavilion 15-b109wm WLAN Module Replacement: adım 12, 3 resimden 3.
    • Using a plastic opening tool, pry open the top cover.
    • Unscrew the two 5 mm screws using a JIS #1 screwdriver.
    • Gently, pull to detach the fan cable.
    • Be careful so you do not damage the motherboard.
  13. HP Pavilion 15-b109wm WLAN Module Replacement: adım 13, 1 resimden 1.
    • Carefully remove the fan from its slot.
  14. HP Pavilion 15-b109wm WLAN Module Replacement, WLAN Module: adım 14, 2 resimden 1. HP Pavilion 15-b109wm WLAN Module Replacement, WLAN Module: adım 14, 2 resimden 2.
    • Remove the 5 mm screw using a JIS #1 screwdriver.
  15. HP Pavilion 15-b109wm WLAN Module Replacement: adım 15, 2 resimden 1. HP Pavilion 15-b109wm WLAN Module Replacement: adım 15, 2 resimden 2.
    • Detach the WLAN Module cords.
  16. HP Pavilion 15-b109wm WLAN Module Replacement: adım 16, 1 resimden 1.
    • Remove the WLAN card and replace it with a new one.
Sonuç
Stephen Gacioch
437 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G2, Peak Fall 2018 UMass Dartmouth, Team S2-G2, Peak Fall 2018 üyesi
UMASSD-PEAK-F18S2G2
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 207
