Giriş
This guide will detail how you can remove the external battery attached to your HP Pavilion 15-ba003ds. You can follow these steps to safely remove your battery and attach a new one. This guide may be of use to you if you’d like to replace your battery.
Unplug the AC adapter from the corresponding socket in the laptop.
Use your fingers to push the slider located just under the battery on either side to unlock the battery from the laptop.
Carefully slide the battery out of the laptop frame and place it somewhere safe.
