Ana içeriğe geç
HP Pavilion 15-ba003ds Charging Port Replacement
Neye ihtiyacın var
  1. HP Pavilion 15-ba003ds Charging Port Replacement, Battery: adım 1, 2 resimden 1. HP Pavilion 15-ba003ds Charging Port Replacement, Battery: adım 1, 2 resimden 2.
    • Unplug the AC adapter from the corresponding socket in the laptop.
    • Turn off your laptop before starting this procedure. Make sure it's not in sleep or hibernation mode.
    • Use your fingers to push the slider located just under the battery on either side to unlock the battery from the laptop.
    • Carefully slide the battery out of the laptop frame and place it somewhere safe.
  2. HP Pavilion 15-ba003ds Charging Port Replacement, Backplate: adım 2, 3 resimden 1. HP Pavilion 15-ba003ds Charging Port Replacement, Backplate: adım 2, 3 resimden 2. HP Pavilion 15-ba003ds Charging Port Replacement, Backplate: adım 2, 3 resimden 3.
    • Use a Jimmy to pry off the black backplate.
  3. HP Pavilion 15-ba003ds Charging Port Replacement, Cooling Fan: adım 3, 2 resimden 1. HP Pavilion 15-ba003ds Charging Port Replacement, Cooling Fan: adım 3, 2 resimden 2.
    • Remove three black 6mm Phillips #00 screws.
  4. HP Pavilion 15-ba003ds Charging Port Replacement: adım 4, 3 resimden 1. HP Pavilion 15-ba003ds Charging Port Replacement: adım 4, 3 resimden 2. HP Pavilion 15-ba003ds Charging Port Replacement: adım 4, 3 resimden 3.
    • Unplug the white connector using your fingers or a spudger.
  5. HP Pavilion 15-ba003ds Charging Port Replacement: adım 5, 3 resimden 1. HP Pavilion 15-ba003ds Charging Port Replacement: adım 5, 3 resimden 2. HP Pavilion 15-ba003ds Charging Port Replacement: adım 5, 3 resimden 3.
    • Pull out the fan by hand.
  6. HP Pavilion 15-ba003ds Charging Port Replacement, Charging Port: adım 6, 1 resimden 1.
    • Use a spudger to disconnect the power cable from the motherboard.
  7. HP Pavilion 15-ba003ds Charging Port Replacement: adım 7, 3 resimden 1. HP Pavilion 15-ba003ds Charging Port Replacement: adım 7, 3 resimden 2. HP Pavilion 15-ba003ds Charging Port Replacement: adım 7, 3 resimden 3.
    • Remove two 8mm Phillips #2 screws from the metal plate.
    • Use your hand to flip the metal plate so you can see the charging port fully.
  8. HP Pavilion 15-ba003ds Charging Port Replacement: adım 8, 2 resimden 1. HP Pavilion 15-ba003ds Charging Port Replacement: adım 8, 2 resimden 2.
    • Use a spudger to pry off the charging port.
Sonuç
LI XU
334 İtibar
2 adet Kılavuz yazıldı
Ekip
1Rehber Yorum
how much does it cost to replace a laptop charging port
Ebele Athekame - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 12
Son 30 gün: 50
Her zaman: 2,427
