Ana içeriğe geç
HP Pavilion 15-ba003ds Cooling Fan Replacement
Neye ihtiyacın var
  1. HP Pavilion 15-ba003ds Cooling Fan Replacement, Battery: adım 1, 2 resimden 1. HP Pavilion 15-ba003ds Cooling Fan Replacement, Battery: adım 1, 2 resimden 2.
    • Unplug the AC adapter from the corresponding socket in the laptop.
    • Turn off your laptop before starting this procedure. Make sure it's not in sleep or hibernation mode.
    • Use your fingers to push the slider located just under the battery on either side to unlock the battery from the laptop.
    • Carefully slide the battery out of the laptop frame and place it somewhere safe.
  2. HP Pavilion 15-ba003ds Cooling Fan Replacement, Disc Drive: adım 2, 1 resimden 1.
    • Remove the two rubber feet next to the battery.
  3. HP Pavilion 15-ba003ds Cooling Fan Replacement: adım 3, 2 resimden 1. HP Pavilion 15-ba003ds Cooling Fan Replacement: adım 3, 2 resimden 2.
    • Remove twelve 8mm Phillips #00 screws including two underneath the rubber feet.
  4. HP Pavilion 15-ba003ds Cooling Fan Replacement: adım 4, 2 resimden 1. HP Pavilion 15-ba003ds Cooling Fan Replacement: adım 4, 2 resimden 2.
    • Pull out the disc drive by hand.
  5. HP Pavilion 15-ba003ds Cooling Fan Replacement, Backplate: adım 5, 3 resimden 1. HP Pavilion 15-ba003ds Cooling Fan Replacement, Backplate: adım 5, 3 resimden 2. HP Pavilion 15-ba003ds Cooling Fan Replacement, Backplate: adım 5, 3 resimden 3.
    • Use a Jimmy to pry off the black backplate.
  6. HP Pavilion 15-ba003ds Cooling Fan Replacement, Cooling Fan: adım 6, 2 resimden 1. HP Pavilion 15-ba003ds Cooling Fan Replacement, Cooling Fan: adım 6, 2 resimden 2.
    • Remove three black 6mm Phillips #00 screws.
  7. HP Pavilion 15-ba003ds Cooling Fan Replacement: adım 7, 3 resimden 1. HP Pavilion 15-ba003ds Cooling Fan Replacement: adım 7, 3 resimden 2. HP Pavilion 15-ba003ds Cooling Fan Replacement: adım 7, 3 resimden 3.
    • Unplug the white connector using your fingers or a spudger.
  8. HP Pavilion 15-ba003ds Cooling Fan Replacement: adım 8, 3 resimden 1. HP Pavilion 15-ba003ds Cooling Fan Replacement: adım 8, 3 resimden 2. HP Pavilion 15-ba003ds Cooling Fan Replacement: adım 8, 3 resimden 3.
    • Pull out the fan by hand.
Sonuç
Krushnam Badami
342 İtibar
3 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 296
