Ana içeriğe geç
HP Pavilion 15-ba003ds Screen Replacement
Neye ihtiyacın var
  1. HP Pavilion 15-ba003ds Screen Replacement, Screen: adım 1, 3 resimden 1. HP Pavilion 15-ba003ds Screen Replacement, Screen: adım 1, 3 resimden 2. HP Pavilion 15-ba003ds Screen Replacement, Screen: adım 1, 3 resimden 3.
    • Apply firm pressure and slide the metal spudger along the outside edges of the front panel screen.
    • When using the metal spudger, be careful not to press into the plastic panel too hard. It may damage internal cables or the panel.
  2. HP Pavilion 15-ba003ds Screen Replacement: adım 2, 3 resimden 1. HP Pavilion 15-ba003ds Screen Replacement: adım 2, 3 resimden 2. HP Pavilion 15-ba003ds Screen Replacement: adım 2, 3 resimden 3.
    • Continue sliding the metal spudger to the bottom of the screen.
    • Don't pull on the frame outwards as this will put pressure on the panel and damage it.
  3. HP Pavilion 15-ba003ds Screen Replacement: adım 3, 3 resimden 1. HP Pavilion 15-ba003ds Screen Replacement: adım 3, 3 resimden 2. HP Pavilion 15-ba003ds Screen Replacement: adım 3, 3 resimden 3.
    • Flip the laptop so the bottom is facing upwards.
    • Using the metal spudger, separate the plastic panel off the screen.
  4. HP Pavilion 15-ba003ds Screen Replacement: adım 4, 3 resimden 1. HP Pavilion 15-ba003ds Screen Replacement: adım 4, 3 resimden 2. HP Pavilion 15-ba003ds Screen Replacement: adım 4, 3 resimden 3.
    • Once the panel is separated from the screen, gently pull it off and set it aside.
    • Remove two 6mm Phillips #00 screws from the bottom of the screen.
  5. HP Pavilion 15-ba003ds Screen Replacement: adım 5, 3 resimden 1. HP Pavilion 15-ba003ds Screen Replacement: adım 5, 3 resimden 2. HP Pavilion 15-ba003ds Screen Replacement: adım 5, 3 resimden 3.
    • Remove two 6mm Phillips #00 screws from the top of the screen.
  6. HP Pavilion 15-ba003ds Screen Replacement: adım 6, 3 resimden 1. HP Pavilion 15-ba003ds Screen Replacement: adım 6, 3 resimden 2. HP Pavilion 15-ba003ds Screen Replacement: adım 6, 3 resimden 3.
    • Flip the screen down.
    • Remove the tape from over the connector.
    • Pull out the connector using your fingers.
  7. HP Pavilion 15-ba003ds Screen Replacement: adım 7, 1 resimden 1.
    • Lift the screen away from the laptop.
Sonuç
Joseph Chia
355 İtibar
3 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 21
Her zaman: 339
