Ana içeriğe geç
HP Pavilion 15-bk020wm Hard Drive Replacement
Neye ihtiyacın var
  1. HP Pavilion 15-bk020wm Hard Drive Replacement, Keyboard Cover: adım 1, 2 resimden 1. HP Pavilion 15-bk020wm Hard Drive Replacement, Keyboard Cover: adım 1, 2 resimden 2.
    • Before you begin, turn the laptop off and unplug it from the power source.
    • Remove the 4 computer feet. (Our device didn't have these; they can be taken off with a plastic spudger.)
    • Remove the two screw cover strips.
    • Remove the two screw cover plugs.
    • Unscrew all 12 screws (size: Phillips M2.5×7.0 ) from the bottom of the computer.
  2. HP Pavilion 15-bk020wm Hard Drive Replacement: adım 2, 3 resimden 1. HP Pavilion 15-bk020wm Hard Drive Replacement: adım 2, 3 resimden 2. HP Pavilion 15-bk020wm Hard Drive Replacement: adım 2, 3 resimden 3.
    • Turn the computer over to the front.
    • Open the laptop.
    • Use a plastic pry tool to pry up the keyboard cover near the hinge on both the right and left side, and work your way towards the touchpad.
  3. HP Pavilion 15-bk020wm Hard Drive Replacement: adım 3, 1 resimden 1.
    • Tilt the keyboard cover up slightly.
    • Do not fully remove the keyboard, as it is still attached to the laptop by some cables.
  4. HP Pavilion 15-bk020wm Hard Drive Replacement, Hard Drive: adım 4, 1 resimden 1.
    • Remove the hard drive from the laptop.
    • Our device did not contain a hard drive.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 37
Her zaman: 17,103
