Ana içeriğe geç
HP Pavilion 15-cc023cl Battery Replacement
Neye ihtiyacın var
  1. HP Pavilion 15-cc023cl Battery Replacement, Battery: adım 1, 2 resimden 1. HP Pavilion 15-cc023cl Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Use a PH000 screwdriver to unscrew the eleven 4mm Phillip head screws located on the back panel.
  2. HP Pavilion 15-cc023cl Battery Replacement: adım 2, 1 resimden 1.
    • Using the iFixit opening tool, pry open and remove the back cover of the laptop.
    • Be gentle when applying force to the cover.
  3. HP Pavilion 15-cc023cl Battery Replacement: adım 3, 2 resimden 1. HP Pavilion 15-cc023cl Battery Replacement: adım 3, 2 resimden 2.
    • Use a PH000 screwdriver to unscrew the four 3.5mm Philips head screws located on the battery.
  4. HP Pavilion 15-cc023cl Battery Replacement: adım 4, 2 resimden 1. HP Pavilion 15-cc023cl Battery Replacement: adım 4, 2 resimden 2.
    • Disconnect the port connecting the battery and the motherboard and then remove.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
2 Yorum
We have a CD player on our laptop. Do we have to do something special with it?
ellenfk91 - Yanıt
If you plan to replace it yeah, what do you even plan to replace? battery, no, harddrive, no, and im not sure about the other stuff.
Don't hurt the chickens -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 40
Her zaman: 3,740
