Ana içeriğe geç
HP Pavilion 15-cc023cl Hard Drive Replacement
Neye ihtiyacın var
  1. HP Pavilion 15-cc023cl Hard Drive Replacement, Battery: adım 1, 2 resimden 1. HP Pavilion 15-cc023cl Hard Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Use a PH000 screwdriver to unscrew the eleven 4mm Phillip head screws located on the back panel.
  2. HP Pavilion 15-cc023cl Hard Drive Replacement: adım 2, 1 resimden 1.
    • Using the iFixit opening tool, pry open and remove the back cover of the laptop.
    • Be gentle when applying force to the cover.
  3. HP Pavilion 15-cc023cl Hard Drive Replacement: adım 3, 2 resimden 1. HP Pavilion 15-cc023cl Hard Drive Replacement: adım 3, 2 resimden 2.
    • Use a PH000 screwdriver to unscrew the four 3.5mm Philips head screws located on the battery.
  4. HP Pavilion 15-cc023cl Hard Drive Replacement: adım 4, 2 resimden 1. HP Pavilion 15-cc023cl Hard Drive Replacement: adım 4, 2 resimden 2.
    • Disconnect the port connecting the battery and the motherboard and then remove.
  5. HP Pavilion 15-cc023cl Hard Drive Replacement, Hard Drive: adım 5, 1 resimden 1.
    • Use a spudger to lift the latch that holds the hard drive cable in place.
  6. HP Pavilion 15-cc023cl Hard Drive Replacement: adım 6, 1 resimden 1.
    • Use a plastic opening tool to pry the hard drive out.
  7. HP Pavilion 15-cc023cl Hard Drive Replacement: adım 7, 1 resimden 1.
    • Disconnect the hard drive cable.
  8. HP Pavilion 15-cc023cl Hard Drive Replacement: adım 8, 1 resimden 1.
    • Lift the plastic wedges up on both sides of the hard drive.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 36
Her zaman: 4,417
