Ana içeriğe geç
HP Pavilion 15-cd040wm Back Cover Disassembly
Neye ihtiyacın var
  1. HP Pavilion 15-cd040wm Back Cover Disassembly, HP Pavilion 15-cd040wm Back Cover Disassembly: adım 1, 2 resimden 1. HP Pavilion 15-cd040wm Back Cover Disassembly, HP Pavilion 15-cd040wm Back Cover Disassembly: adım 1, 2 resimden 2.
    • The first step is to remove the four rubber non-slip pads on the bottom of the laptop to expose screws hidden underneath them. Peel off each tab with your fingers.
    • If you have trouble gripping a tab, use a spudger to wedge it loose.
  2. HP Pavilion 15-cd040wm Back Cover Disassembly: adım 2, 2 resimden 1. HP Pavilion 15-cd040wm Back Cover Disassembly: adım 2, 2 resimden 2.
    • 3x 10mm Phillips scews
    • 2x 5mm Phillips screws
    • 6x 6mm Phillips screws
    • Remove all screws using a size Phillips #0 screwdriver.
  3. HP Pavilion 15-cd040wm Back Cover Disassembly: adım 3, 3 resimden 1. HP Pavilion 15-cd040wm Back Cover Disassembly: adım 3, 3 resimden 2. HP Pavilion 15-cd040wm Back Cover Disassembly: adım 3, 3 resimden 3.
    • Using the iFixit opening tool, carefully pry along the sides of the back cover.
    • After all of the edges of the back cover have been freed, use your opening tool to carefully unclip the tabs holding the back cover to the CD drive.
    • After everything is unclipped, you can safely remove the back cover from the rest of the device.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Joe Krawczyk
397 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G1, Botvin Fall 2019 UMass Dartmouth, Team S1-G1, Botvin Fall 2019 üyesi
UMASSD-BOTVIN-F19S1G1
4 Üyeler
7 adet Kılavuz yazıldı
3 Yorum
It's not listed in here, but to remove the cd tray, just pull it straight out. The whole drive has a connector at the back.
Gage Cook - Yanıt
I’m trying to remove my backing and it seems to have a lip that goes over the edge, so I’m having a hard time getting it apart. Any suggestions?
Laura Green - Yanıt
Is this the same process for the HP Pavilion 15-cc055od? Do I pull out the disk drive as well? How would I remove the hard drive?
Baconface Smith - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 25
Son 30 gün: 117
Her zaman: 8,565
