Ana içeriğe geç
HP Pavilion 15-cd040wm Hard Drive Replacement
Neye ihtiyacın var
  1. HP Pavilion 15-cd040wm Hard Drive Replacement, HP Pavilion 15-cd040wm Back Cover Disassembly: adım 1, 2 resimden 1. HP Pavilion 15-cd040wm Hard Drive Replacement, HP Pavilion 15-cd040wm Back Cover Disassembly: adım 1, 2 resimden 2.
    • The first step is to remove the four rubber non-slip pads on the bottom of the laptop to expose screws hidden underneath them. Peel off each tab with your fingers.
    • If you have trouble gripping a tab, use a spudger to wedge it loose.
  2. HP Pavilion 15-cd040wm Hard Drive Replacement: adım 2, 2 resimden 1. HP Pavilion 15-cd040wm Hard Drive Replacement: adım 2, 2 resimden 2.
    • 3x 10mm Phillips scews
    • 2x 5mm Phillips screws
    • 6x 6mm Phillips screws
    • Remove all screws using a size Phillips #0 screwdriver.
  3. HP Pavilion 15-cd040wm Hard Drive Replacement: adım 3, 3 resimden 1. HP Pavilion 15-cd040wm Hard Drive Replacement: adım 3, 3 resimden 2. HP Pavilion 15-cd040wm Hard Drive Replacement: adım 3, 3 resimden 3.
    • Using the iFixit opening tool, carefully pry along the sides of the back cover.
    • After all of the edges of the back cover have been freed, use your opening tool to carefully unclip the tabs holding the back cover to the CD drive.
    • After everything is unclipped, you can safely remove the back cover from the rest of the device.
  4. HP Pavilion 15-cd040wm Hard Drive Replacement, Battery: adım 4, 2 resimden 1. HP Pavilion 15-cd040wm Hard Drive Replacement, Battery: adım 4, 2 resimden 2.
    • 2x 5mm Philips screws
    • 2x 3mm Philips screws
  5. HP Pavilion 15-cd040wm Hard Drive Replacement: adım 5, 2 resimden 1. HP Pavilion 15-cd040wm Hard Drive Replacement: adım 5, 2 resimden 2.
    • Gently pull up on the battery and tilt it away from the rest of the laptop chassis.
    • Pull out the battery at an angle and lift it out of the laptop.
  6. HP Pavilion 15-cd040wm Hard Drive Replacement, Hard Drive: adım 6, 2 resimden 1. HP Pavilion 15-cd040wm Hard Drive Replacement, Hard Drive: adım 6, 2 resimden 2.
    • Using a spudger or the opening tool, lift the end closest to the battery until you can hold the hard drive with your hands.
  7. HP Pavilion 15-cd040wm Hard Drive Replacement: adım 7, 2 resimden 1. HP Pavilion 15-cd040wm Hard Drive Replacement: adım 7, 2 resimden 2.
    • Carefully remove the connector ribbon cable from the elevated end of the hard drive, then remove the hard drive.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Brian Cornet
316 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G1, Botvin Fall 2019 UMass Dartmouth, Team S1-G1, Botvin Fall 2019 üyesi
UMASSD-BOTVIN-F19S1G1
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 15
Her zaman: 1,873
