Ana içeriğe geç
HP Pavilion 15-e043cl Hard Drive Replacement
Neye ihtiyacın var
  1. HP Pavilion 15-e043cl Hard Drive Replacement, Battery: adım 1, 2 resimden 1. HP Pavilion 15-e043cl Hard Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the device over.
    • Slide the battery switch on the right half of the laptop.
    • Make sure the device is powered off, and that it is not connected to any power sources.
    FixBot'a Sor
    Yorum Ekle
  2. HP Pavilion 15-e043cl Hard Drive Replacement: adım 2, 2 resimden 1. HP Pavilion 15-e043cl Hard Drive Replacement: adım 2, 2 resimden 2.
    • Lift the battery up and out of the device by the inward-facing edge.
    FixBot'a Sor
    Yorum Ekle
  3. HP Pavilion 15-e043cl Hard Drive Replacement, Maintenance Panel: adım 3, 3 resimden 1. HP Pavilion 15-e043cl Hard Drive Replacement, Maintenance Panel: adım 3, 3 resimden 2. HP Pavilion 15-e043cl Hard Drive Replacement, Maintenance Panel: adım 3, 3 resimden 3.
    • Unscrew the single Phillips #0 captive screw that was previously hidden by the battery.
    • The screw can not, and should not, be fully removed.
    • Slide the maintenance panel away from the battery compartment to release it.
    FixBot'a Sor
    Yorum Ekle
  4. HP Pavilion 15-e043cl Hard Drive Replacement, Hard Drive: adım 4, 2 resimden 1. HP Pavilion 15-e043cl Hard Drive Replacement, Hard Drive: adım 4, 2 resimden 2.
    • Unscrew the two black Phillips #0 screws securing the hard drive.
    • Lift the hard drive a few centimeters out of the laptop, with care not to damage the cable.
    • Unplug the hard drive from the laptop.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Cace Letendre
528 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-5, Sinclaire Fall 2022 UMass Dartmouth, Team 4-5, Sinclaire Fall 2022 üyesi
UMASSD-SINCLAIRE-F22S4G5
5 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 27
Her zaman: 480
