Ana içeriğe geç
HP Pavilion 15-e043cl RAM Replacement
Neye ihtiyacın var
    1. HP Pavilion 15-e043cl RAM Replacement, Battery: adım 1, 2 resimden 1. HP Pavilion 15-e043cl RAM Replacement, Battery: adım 1, 2 resimden 2.
      • Flip the device over.
      • Slide the battery switch on the right half of the laptop.
      • Make sure the device is powered off, and that it is not connected to any power sources.
      FixBot'a Sor
      Yorum Ekle
    2. HP Pavilion 15-e043cl RAM Replacement: adım 2, 2 resimden 1. HP Pavilion 15-e043cl RAM Replacement: adım 2, 2 resimden 2.
      • Lift the battery up and out of the device by the inward-facing edge.
      FixBot'a Sor
      Yorum Ekle
    1. HP Pavilion 15-e043cl RAM Replacement, Maintenance Panel: adım 3, 3 resimden 1. HP Pavilion 15-e043cl RAM Replacement, Maintenance Panel: adım 3, 3 resimden 2. HP Pavilion 15-e043cl RAM Replacement, Maintenance Panel: adım 3, 3 resimden 3.
      • Unscrew the single Phillips #0 captive screw that was previously hidden by the battery.
      • The screw can not, and should not, be fully removed.
      • Slide the maintenance panel away from the battery compartment to release it.
      FixBot'a Sor
      Yorum Ekle
    1. HP Pavilion 15-e043cl RAM Replacement, RAM: adım 4, 2 resimden 1. HP Pavilion 15-e043cl RAM Replacement, RAM: adım 4, 2 resimden 2.
      • Push the two silver arms away from the RAM card.
      • Pull the RAM card out of its slot.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Cace Letendre
528 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-5, Sinclaire Fall 2022 UMass Dartmouth, Team 4-5, Sinclaire Fall 2022 üyesi
UMASSD-SINCLAIRE-F22S4G5
5 Üyeler
47 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 31
Her zaman: 399
