Ana içeriğe geç
HP Pavilion 15-n232nr Cooling Fan Replacement
Neye ihtiyacın var
  1. HP Pavilion 15-n232nr Cooling Fan Replacement, Battery: adım 1, 2 resimden 1. HP Pavilion 15-n232nr Cooling Fan Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the laptop over.
  2. HP Pavilion 15-n232nr Cooling Fan Replacement: adım 2, 3 resimden 1. HP Pavilion 15-n232nr Cooling Fan Replacement: adım 2, 3 resimden 2. HP Pavilion 15-n232nr Cooling Fan Replacement: adım 2, 3 resimden 3.
    • Slide the battery locks towards the center of the laptop. The battery will detach automatically.
    • Remove the battery by sliding it away from the laptop housing.
  3. HP Pavilion 15-n232nr Cooling Fan Replacement, Optical Drive: adım 3, 2 resimden 1. HP Pavilion 15-n232nr Cooling Fan Replacement, Optical Drive: adım 3, 2 resimden 2.
    • Remove the 6 mm Phillips #1 screw securing the optical drive.
  4. HP Pavilion 15-n232nr Cooling Fan Replacement: adım 4, 2 resimden 1. HP Pavilion 15-n232nr Cooling Fan Replacement: adım 4, 2 resimden 2.
    • Use the iFixit opening tool to slide the optical drive away from the laptop housing.
  5. HP Pavilion 15-n232nr Cooling Fan Replacement, Keyboard: adım 5, 2 resimden 1. HP Pavilion 15-n232nr Cooling Fan Replacement, Keyboard: adım 5, 2 resimden 2.
    • Unscrew the 6 mm Phillips #1 screw securing the keyboard.
  6. HP Pavilion 15-n232nr Cooling Fan Replacement: adım 6, 2 resimden 1. HP Pavilion 15-n232nr Cooling Fan Replacement: adım 6, 2 resimden 2.
    • Flip the laptop to the front side and open it up.
  7. HP Pavilion 15-n232nr Cooling Fan Replacement: adım 7, 2 resimden 1. HP Pavilion 15-n232nr Cooling Fan Replacement: adım 7, 2 resimden 2.
    • Use the metal spudger to release the keyboard from the front panel.
  8. HP Pavilion 15-n232nr Cooling Fan Replacement: adım 8, 3 resimden 1. HP Pavilion 15-n232nr Cooling Fan Replacement: adım 8, 3 resimden 2. HP Pavilion 15-n232nr Cooling Fan Replacement: adım 8, 3 resimden 3.
    • Flip the keyboard out and locate the connector.
    • Use the spudger to unhinge the the fastener and remove the connector.
    • Keyboard should be completely detached after this step.
  9. HP Pavilion 15-n232nr Cooling Fan Replacement, RAM: adım 9, 2 resimden 1. HP Pavilion 15-n232nr Cooling Fan Replacement, RAM: adım 9, 2 resimden 2.
    • Loosen the two 6 mm Phillips #1 screws on the back panel.
    • These screws do not detach from back panel.
  10. HP Pavilion 15-n232nr Cooling Fan Replacement: adım 10, 2 resimden 1. HP Pavilion 15-n232nr Cooling Fan Replacement: adım 10, 2 resimden 2.
    • Use the iFixit opening tool to remove the back panel.
  11. HP Pavilion 15-n232nr Cooling Fan Replacement: adım 11, 2 resimden 1. HP Pavilion 15-n232nr Cooling Fan Replacement: adım 11, 2 resimden 2.
    • Release the clips securing the RAM by slightly bending them until the RAM is free.
  12. HP Pavilion 15-n232nr Cooling Fan Replacement, Hard Drive: adım 12, 2 resimden 1. HP Pavilion 15-n232nr Cooling Fan Replacement, Hard Drive: adım 12, 2 resimden 2.
    • The battery and optical drive should be removed at this point in the process.
    • Remove the ten 6 mm Phillips #1 screws.
    • Remove the three 1 mm Phillips #000 screws.
  13. HP Pavilion 15-n232nr Cooling Fan Replacement: adım 13, 2 resimden 1. HP Pavilion 15-n232nr Cooling Fan Replacement: adım 13, 2 resimden 2.
    • Remove the five 2.5mm Phillips #1 screws.
    • Use the spudger to unhinge the cable connectors. Use tweezers to complete removal.
  14. HP Pavilion 15-n232nr Cooling Fan Replacement: adım 14, 3 resimden 1. HP Pavilion 15-n232nr Cooling Fan Replacement: adım 14, 3 resimden 2. HP Pavilion 15-n232nr Cooling Fan Replacement: adım 14, 3 resimden 3.
    • Carefully use the iFixit opening tool to release the front panel.
  15. HP Pavilion 15-n232nr Cooling Fan Replacement: adım 15, 3 resimden 1. HP Pavilion 15-n232nr Cooling Fan Replacement: adım 15, 3 resimden 2. HP Pavilion 15-n232nr Cooling Fan Replacement: adım 15, 3 resimden 3.
    • Use the spudger to unhinge the daughterboard connector.
    • Remove daughterboard connector.
  16. HP Pavilion 15-n232nr Cooling Fan Replacement: adım 16, 1 resimden 1.
    • Remove the 2.5 mm Phillips #1 screw and remove the daughterboard
  17. HP Pavilion 15-n232nr Cooling Fan Replacement: adım 17, 3 resimden 1. HP Pavilion 15-n232nr Cooling Fan Replacement: adım 17, 3 resimden 2. HP Pavilion 15-n232nr Cooling Fan Replacement: adım 17, 3 resimden 3.
    • Use the iFixit opening tool to remove the hard drive connector.
    • Remove the hard drive by lifting the right side and pulling it out.
  18. HP Pavilion 15-n232nr Cooling Fan Replacement, Cooling Fan: adım 18, 3 resimden 1. HP Pavilion 15-n232nr Cooling Fan Replacement, Cooling Fan: adım 18, 3 resimden 2. HP Pavilion 15-n232nr Cooling Fan Replacement, Cooling Fan: adım 18, 3 resimden 3.
    • Remove the four 6 mm Phillips #1 screws.
    • Turn over the laptop to have easier access to the cooling fan.
  19. HP Pavilion 15-n232nr Cooling Fan Replacement: adım 19, 3 resimden 1. HP Pavilion 15-n232nr Cooling Fan Replacement: adım 19, 3 resimden 2. HP Pavilion 15-n232nr Cooling Fan Replacement: adım 19, 3 resimden 3.
    • Unscrew the two 4 mm Phillips #1 screws.
    • Disconnect the cord for the cooling fan.
    • Carefully lift the cooling fan from the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
[deleted]
262 İtibar
2 adet Kılavuz yazıldı
Bir Yorum
Sehr gute Anleitung, Dank an Andrei Fendly
H. Hofmann
Helmut Hofmann - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 716
