Ana içeriğe geç
HP Pavilion 15-p Palmrest Replacement
Neye ihtiyacın var
  1. HP Pavilion 15-p Palmrest Replacement, Prepare the laptop: adım 1, 3 resimden 1. HP Pavilion 15-p Palmrest Replacement, Prepare the laptop: adım 1, 3 resimden 2. HP Pavilion 15-p Palmrest Replacement, Prepare the laptop: adım 1, 3 resimden 3.
    • Shut the laptop down until it is hibernated or shut off. Do not remove power until both lights turn off.
  2. HP Pavilion 15-p Palmrest Replacement, Unlock the  battery: adım 2, 3 resimden 1. HP Pavilion 15-p Palmrest Replacement, Unlock the  battery: adım 2, 3 resimden 2. HP Pavilion 15-p Palmrest Replacement, Unlock the  battery: adım 2, 3 resimden 3.
    • Once the computer is off, remove the battery. Switch the locking tab to the unlocked position.
  3. HP Pavilion 15-p Palmrest Replacement, Remove the battery: adım 3, 2 resimden 1. HP Pavilion 15-p Palmrest Replacement, Remove the battery: adım 3, 2 resimden 2.
    • Remove the battery. Pull the battery forward and remove it from the laptop.
  4. HP Pavilion 15-p Palmrest Replacement, Remove the optical drive: adım 4, 3 resimden 1. HP Pavilion 15-p Palmrest Replacement, Remove the optical drive: adım 4, 3 resimden 2. HP Pavilion 15-p Palmrest Replacement, Remove the optical drive: adım 4, 3 resimden 3.
    • EET owners: Your kit has this bit. No purchase needed.
    • Remove the screw that holds the optical drive in. To do this, use a Phillips #0 screwdriver. Slide the optical drive out once the screw is removed.
  5. HP Pavilion 15-p Palmrest Replacement, Remove the screws under the optical drive: adım 5, 1 resimden 1.
    • The system used in the guide only came with one screw. If yours came with three, sort accordingly.
    • With the palmrest screws removed, remove the screws under the optical drive. Use a Phillips #000 screwdriver.
  6. HP Pavilion 15-p Palmrest Replacement, Remove the bottom screws: adım 6, 1 resimden 1.
    • Once the battery and optical drive are removed, remove the 11 Phillips #0 screws that secure the palmrest.
    • This screw is hidden by a sticker. If lost/damaged, it is cosmetic.
    • Not found on all models. On some models, there are screws in this area. If you see screws here, they must be removed.
  7. HP Pavilion 15-p Palmrest Replacement, Remove the hinge caps: adım 7, 3 resimden 1. HP Pavilion 15-p Palmrest Replacement, Remove the hinge caps: adım 7, 3 resimden 2. HP Pavilion 15-p Palmrest Replacement, Remove the hinge caps: adım 7, 3 resimden 3.
    • If you choose to reuse the original pads, stick them to the hinge caps to preserve the adhesive.
    • Remove the hinge caps. To do this, remove the rubber pads. Use a Phillps #0 screwdriver.
    • Remove the screws under the hinge caps. To do this, use a Phillps #0 screwdriver.
  8. HP Pavilion 15-p Palmrest Replacement, Unsnap the palmrest: adım 8, 3 resimden 1. HP Pavilion 15-p Palmrest Replacement, Unsnap the palmrest: adım 8, 3 resimden 2. HP Pavilion 15-p Palmrest Replacement, Unsnap the palmrest: adım 8, 3 resimden 3.
    • EET owners: Your kit has the needed picks. No purchase needed.
    • Do not fully remove the palmrest - the power button is still connected to the motherboard.
    • If you are having trouble removing the palmrest, try using a guitar pick.
    • Run a plastic tool around all 3 sides of the palmrest. Once they are loose, disconnect the keyboard and trackpad. Flip the black plastic tabs on the connectors up and disconnect the cables.
    • Once the keyboard and trackpad are disconnected, the palmrest can be lifted up. In some cases, further prying may be needed.
  9. HP Pavilion 15-p Palmrest Replacement, Disconnect the power button: adım 9, 3 resimden 1. HP Pavilion 15-p Palmrest Replacement, Disconnect the power button: adım 9, 3 resimden 2. HP Pavilion 15-p Palmrest Replacement, Disconnect the power button: adım 9, 3 resimden 3.
    • With the keyboard and trackpad disconnected, disconnect the power button. Flip the black tab up and remove the palmrest.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Nick
93.776 İtibar
59 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
326 Üyeler
1.672 adet Kılavuz yazıldı
6Kılavuz Yorumları
My power button is bad and my mouse track stopped working. I couldn't find a replacement for it. What can I do?
Trevor Gilbert - Yanıt
hi where can i source a replacement palm rest assembly for my hp pavilion 15 2015. its the same as the first laptop picture
Oche Ejiga - Yanıt
You have the US ENG keyboard most likely. I posted the parts list as new steps (762529-001 or 762530-001). Verify it based on the part number sticker to be absolutely sure though but that is likely a match.
Nick -
Hi my hinge broke off and so was some of my speaker. Plus, its making my screen close on its own and I can't keep it still. :( Where can I get a replacement for the palmrest, keyboard, and touchpad? My model for my hp pavillion laptop is: 3C310UA#ABA
thecrowrules1982 - Yanıt
Parts laptop, or a junk laptop with a bad motherboard (BIOS lock or dead power). The bare part tends to be ~$150+ if it's available and will only get worse as they become hard to find.
Nick -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 69
Her zaman: 6,970
