Ana içeriğe geç
HP Pavilion 15-p043cl Repair Optical Drive Replacement
Neye ihtiyacın var
  1. HP Pavilion 15-p043cl Repair Optical Drive Replacement, Optical Drive: adım 1, 2 resimden 1. HP Pavilion 15-p043cl Repair Optical Drive Replacement, Optical Drive: adım 1, 2 resimden 2.
    • Flip over the laptop so that the screws on the bottom are exposed.
  2. HP Pavilion 15-p043cl Repair Optical Drive Replacement: adım 2, 2 resimden 1. HP Pavilion 15-p043cl Repair Optical Drive Replacement: adım 2, 2 resimden 2.
    • Use a #1 Phillips screwdriver to remove the single 8 mm screw that secures the optical drive.
    • There is a CD/DVD symbol on the case that helps identify the correct screw.
  3. HP Pavilion 15-p043cl Repair Optical Drive Replacement: adım 3, 3 resimden 1. HP Pavilion 15-p043cl Repair Optical Drive Replacement: adım 3, 3 resimden 2. HP Pavilion 15-p043cl Repair Optical Drive Replacement: adım 3, 3 resimden 3.
    • Use your fingers or a wedge to pull out the Optical Drive from it's slot.
    • If the faceplate of the drive is pulled off it can be reattached.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 65
