Ana içeriğe geç
HP Pavilion 15-p214dx Battery Replacement
Neye ihtiyacın var
  1. HP Pavilion 15-p214dx Battery Replacement, Battery: adım 1, 2 resimden 1. HP Pavilion 15-p214dx Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Slide the battery lock (the switch at the upper left corner of the laptop's underside) to the right until it clicks into place.
  2. HP Pavilion 15-p214dx Battery Replacement: adım 2, 2 resimden 1. HP Pavilion 15-p214dx Battery Replacement: adım 2, 2 resimden 2.
    • Slide the battery release latch (the upper right-hand switch on the laptop's bottom) to the left.
    • While holding the latch in place, remove the battery from the laptop's battery bay.
    • When inserting a battery into the battery bay, the battery release latch does not need to be held open.
Sonuç
To reassemble your device, follow these instructions in reverse order. Opening the battery release latch is not required to plug the battery back in.
Patrick Seaver
1.001 İtibar
8 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G1, Simcock Spring 2019 UMass Dartmouth, Team S2-G1, Simcock Spring 2019 üyesi
UMASSD-SIMCOCK-S19S2G1
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 19
Her zaman: 611
