Ana içeriğe geç
HP Pavilion 15-p214dx Disk Drive Replacement
Neye ihtiyacın var
  1. HP Pavilion 15-p214dx Disk Drive Replacement, Disk Drive: adım 1, 3 resimden 1. HP Pavilion 15-p214dx Disk Drive Replacement, Disk Drive: adım 1, 3 resimden 2. HP Pavilion 15-p214dx Disk Drive Replacement, Disk Drive: adım 1, 3 resimden 3.
    • Place your laptop on a flat surface with the bottom facing upwards. The HP logo should be facing downwards.
    • Locate the disk drive screw. It is a 7mm screw that can be found to the upper left on label on the bottom of the computer and is marked with a disk drive symbol.
    • Remove this screw using a Philips #0 screwdriver.
  2. HP Pavilion 15-p214dx Disk Drive Replacement: adım 2, 2 resimden 1. HP Pavilion 15-p214dx Disk Drive Replacement: adım 2, 2 resimden 2.
    • Place your thumbnail between the disk drive exterior and your laptop's bottom cover.
    • If your nail is not long enough to do this, you can use a prying tool instead.
    • Pull outwards to slide the disk drive out of its slot.
    • Due to how the disk drive's slot is constructed, the drive must be properly aligned to fit back in. It may take a couple attempts to properly align it.
Sonuç
Patrick Seaver
1.001 İtibar
8 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G1, Simcock Spring 2019 UMass Dartmouth, Team S2-G1, Simcock Spring 2019 üyesi
UMASSD-SIMCOCK-S19S2G1
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 248
