Ana içeriğe geç
HP Pavilion 15-p214dx Motherboard Replacement
Neye ihtiyacın var
  1. HP Pavilion 15-p214dx Motherboard Replacement, Disk Drive: adım 1, 3 resimden 1. HP Pavilion 15-p214dx Motherboard Replacement, Disk Drive: adım 1, 3 resimden 2. HP Pavilion 15-p214dx Motherboard Replacement, Disk Drive: adım 1, 3 resimden 3.
    • Place your laptop on a flat surface with the bottom facing upwards. The HP logo should be facing downwards.
    • Locate the disk drive screw. It is a 7mm screw that can be found to the upper left on label on the bottom of the computer and is marked with a disk drive symbol.
    • Remove this screw using a Philips #0 screwdriver.
  2. HP Pavilion 15-p214dx Motherboard Replacement: adım 2, 2 resimden 1. HP Pavilion 15-p214dx Motherboard Replacement: adım 2, 2 resimden 2.
    • Place your thumbnail between the disk drive exterior and your laptop's bottom cover.
    • If your nail is not long enough to do this, you can use a prying tool instead.
    • Pull outwards to slide the disk drive out of its slot.
    • Due to how the disk drive's slot is constructed, the drive must be properly aligned to fit back in. It may take a couple attempts to properly align it.
  3. HP Pavilion 15-p214dx Motherboard Replacement, Top Cover: adım 3, 1 resimden 1.
    • Using a magnetic screwdriver with a Philips #0 head, remove all of the visible screws on your laptop's bottom face. These screws are all about 7.5mm long.
  4. HP Pavilion 15-p214dx Motherboard Replacement: adım 4, 2 resimden 1. HP Pavilion 15-p214dx Motherboard Replacement: adım 4, 2 resimden 2.
    • Remove the 5.5mm screws holding the computer's end caps in place. The end caps are located to the left and right of the battery.
    • These screws are normally hidden underneath the end caps' rubber feet, which are not shown in the pictures. To remove these, gently pry them out of their slots with a plastic opening tool or a flathead screwdriver.
  5. HP Pavilion 15-p214dx Motherboard Replacement: adım 5, 3 resimden 1. HP Pavilion 15-p214dx Motherboard Replacement: adım 5, 3 resimden 2. HP Pavilion 15-p214dx Motherboard Replacement: adım 5, 3 resimden 3.
    • Lift both end caps from their respective corners.
    • Use a Philips #0 screwdriver to remove the 4.3mm screw that is underneath both end caps.
  6. HP Pavilion 15-p214dx Motherboard Replacement: adım 6, 3 resimden 1. HP Pavilion 15-p214dx Motherboard Replacement: adım 6, 3 resimden 2. HP Pavilion 15-p214dx Motherboard Replacement: adım 6, 3 resimden 3.
    • Use a Philips #0 screwdriver to remove the three 5.5mm screws in on the edge of the disk drive slot.
    • These three screws are missing from the pictures.
  7. HP Pavilion 15-p214dx Motherboard Replacement: adım 7, 1 resimden 1.
    • Flip your computer so that the bottom is now on the surface. Open the laptop like you normally would if you were about to use it.
    • Use a plastic opening tool to separate the top cover from the bottom cover.
    • Be careful when prying the cover off since it is susceptible to bending and cracking.
    • There are several cables connecting the top cover to the computer's motherboard that need to be disconnected before the cover can be completely removed.
  8. HP Pavilion 15-p214dx Motherboard Replacement: adım 8, 2 resimden 1. HP Pavilion 15-p214dx Motherboard Replacement: adım 8, 2 resimden 2.
    • While lifting the top cover, undo the clip holding the keyboard cable in place.
    • Slide the cable out of its port.
  9. HP Pavilion 15-p214dx Motherboard Replacement: adım 9, 1 resimden 1.
    • Undo the clip holding the touchpad cable in place.
    • Remove the touchpad cable from its port.
  10. HP Pavilion 15-p214dx Motherboard Replacement: adım 10, 2 resimden 1. HP Pavilion 15-p214dx Motherboard Replacement: adım 10, 2 resimden 2.
    • Undo the clip holding the power button cable in place.
    • Disconnect the power button cable from its port.
    • Gently lift the top cover to remove it from the computer.
  11. HP Pavilion 15-p214dx Motherboard Replacement, Motherboard: adım 11, 3 resimden 1. HP Pavilion 15-p214dx Motherboard Replacement, Motherboard: adım 11, 3 resimden 2. HP Pavilion 15-p214dx Motherboard Replacement, Motherboard: adım 11, 3 resimden 3.
    • Notice that the motherboard is connected to multiple components of the computer that need to be disconnected first
  12. HP Pavilion 15-p214dx Motherboard Replacement: adım 12, 3 resimden 1. HP Pavilion 15-p214dx Motherboard Replacement: adım 12, 3 resimden 2. HP Pavilion 15-p214dx Motherboard Replacement: adım 12, 3 resimden 3.
    • Use a plastic opening tool to separate the speaker's cable from the mother board, by pushing on the speaker's plugged cable
  13. HP Pavilion 15-p214dx Motherboard Replacement: adım 13, 3 resimden 1. HP Pavilion 15-p214dx Motherboard Replacement: adım 13, 3 resimden 2. HP Pavilion 15-p214dx Motherboard Replacement: adım 13, 3 resimden 3.
    • Dismount the power supply cable holding the motherboard, by removing the 5.5 mm screws shown in the first picture on the right, using a Philips #0 screwdriver to remove the screws.
  14. HP Pavilion 15-p214dx Motherboard Replacement: adım 14, 3 resimden 1. HP Pavilion 15-p214dx Motherboard Replacement: adım 14, 3 resimden 2. HP Pavilion 15-p214dx Motherboard Replacement: adım 14, 3 resimden 3.
    • Remove the metal cover to free the motherboard supply cable.
  15. HP Pavilion 15-p214dx Motherboard Replacement: adım 15, 3 resimden 1. HP Pavilion 15-p214dx Motherboard Replacement: adım 15, 3 resimden 2. HP Pavilion 15-p214dx Motherboard Replacement: adım 15, 3 resimden 3.
    • Undo the clip holding the display cable.
    • Gently remove and disconnect the display cable.
  16. HP Pavilion 15-p214dx Motherboard Replacement: adım 16, 3 resimden 1. HP Pavilion 15-p214dx Motherboard Replacement: adım 16, 3 resimden 2. HP Pavilion 15-p214dx Motherboard Replacement: adım 16, 3 resimden 3.
    • Disconnect the disc drive cable by undoing the clip.
    • Repeat the same step for the the hard drive cable.
    • Note there is no need to completely remove the hard drive, just undoing the cable from the motherboard should be sufficient.
  17. HP Pavilion 15-p214dx Motherboard Replacement: adım 17, 3 resimden 1. HP Pavilion 15-p214dx Motherboard Replacement: adım 17, 3 resimden 2. HP Pavilion 15-p214dx Motherboard Replacement: adım 17, 3 resimden 3.
    • Remove the 7mm screws holding the computer's motherboard in place.
    • Using a magnetic screwdriver with a Philips #0 head, remove all of the visible screws on your laptop's motherboard corners.
  18. HP Pavilion 15-p214dx Motherboard Replacement: adım 18, 3 resimden 1. HP Pavilion 15-p214dx Motherboard Replacement: adım 18, 3 resimden 2. HP Pavilion 15-p214dx Motherboard Replacement: adım 18, 3 resimden 3.
    • After the motherboard is dismounted and all the cable are disconnected, remove the motherboard from the device.
Sonuç
Patrick Seaver
1.001 İtibar
8 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G1, Simcock Spring 2019 UMass Dartmouth, Team S2-G1, Simcock Spring 2019 üyesi
UMASSD-SIMCOCK-S19S2G1
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 943
