Ana içeriğe geç
HP Pavilion 17 TS Disk Drive Replacement
Neye ihtiyacın var
  1. HP Pavilion 17 TS Disk Drive Replacement, Battery: adım 1, 3 resimden 1. HP Pavilion 17 TS Disk Drive Replacement, Battery: adım 1, 3 resimden 2. HP Pavilion 17 TS Disk Drive Replacement, Battery: adım 1, 3 resimden 3.
    • Press and hold the release switch, and then slide the battery out. Insert the new battery into the slot and you're done!
  2. HP Pavilion 17 TS Disk Drive Replacement, Rear Cover: adım 2, 3 resimden 1. HP Pavilion 17 TS Disk Drive Replacement, Rear Cover: adım 2, 3 resimden 2. HP Pavilion 17 TS Disk Drive Replacement, Rear Cover: adım 2, 3 resimden 3.
    • In the battery compartment, find the phillips screw that is holding the rear panel onto the computer. Unscrew it.
    • With the battery compartment closest to you, push the panel away from you. Once it slides back until it stops, gently lift it and put it to the side.
    • Please note that this particular screw does not completely come out, it stays with the rear panel and that is ok.
  3. HP Pavilion 17 TS Disk Drive Replacement, Disk Drive: adım 3, 3 resimden 1. HP Pavilion 17 TS Disk Drive Replacement, Disk Drive: adım 3, 3 resimden 2. HP Pavilion 17 TS Disk Drive Replacement, Disk Drive: adım 3, 3 resimden 3.
    • With the battery compartment closest to you, there will be a 9mm screw next in the center-right of the back plate, labeled with a keyboard symbol and a disk symbol. Remove this phillips screw.
    • In the opening next to the screw, gently push out against the disk drive, and remove it from the disk drive compartment.
Sonuç
Eric Sowersby
413 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-6, Miles Spring 2016 UMass Dartmouth, Team 1-6, Miles Spring 2016 üyesi
UMASSD-MILES-S16S1G6
3 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 520
