Ana içeriğe geç
Giriş
The rear plate acts like a shield. It protects your most important components from outside interference, like damage and to some extent, dust. This guide will show you how to remove it.
Parçalar
Hiçbir parça belirtilmedi.
  1. Press and hold the release switch, and then slide the battery out. Insert the new battery into the slot and you're done! Press and hold the release switch, and then slide the battery out. Insert the new battery into the slot and you're done! Press and hold the release switch, and then slide the battery out. Insert the new battery into the slot and you're done!
    • Press and hold the release switch, and then slide the battery out. Insert the new battery into the slot and you're done!
  2. Dizüstü Bilgisayar Bataryaları
    An easy fix for a big power boost.
    Hemen Alışveriş Yapın
  3. In the battery compartment, find the phillips screw that is holding the rear panel onto the computer. Unscrew it. With the battery compartment closest to you, push the panel away from you. Once it slides back until it stops, gently lift it and put it to the side. Please note that this particular screw does not completely come out, it stays with the rear panel and that is ok.
    • In the battery compartment, find the phillips screw that is holding the rear panel onto the computer. Unscrew it.
    • With the battery compartment closest to you, push the panel away from you. Once it slides back until it stops, gently lift it and put it to the side.
    • Please note that this particular screw does not completely come out, it stays with the rear panel and that is ok.
Sonuç
Sean Croft
715 İtibar
5 adet Kılavuz yazıldı
Takım
UMass Dartmouth, Team 1-6, Miles Spring 2016 UMass Dartmouth, Team 1-6, Miles Spring 2016 üyesi
UMASSD-MILES-S16S1G6
3 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 2
Her zaman: 312
