Ana içeriğe geç
HP Pavilion 17 TS Wireless Card Replacement
Neye ihtiyacın var
  1. HP Pavilion 17 TS Wireless Card Replacement, Battery: adım 1, 3 resimden 1. HP Pavilion 17 TS Wireless Card Replacement, Battery: adım 1, 3 resimden 2. HP Pavilion 17 TS Wireless Card Replacement, Battery: adım 1, 3 resimden 3.
    • Press and hold the release switch, and then slide the battery out. Insert the new battery into the slot and you're done!
  2. HP Pavilion 17 TS Wireless Card Replacement, Rear Cover: adım 2, 3 resimden 1. HP Pavilion 17 TS Wireless Card Replacement, Rear Cover: adım 2, 3 resimden 2. HP Pavilion 17 TS Wireless Card Replacement, Rear Cover: adım 2, 3 resimden 3.
    • In the battery compartment, find the phillips screw that is holding the rear panel onto the computer. Unscrew it.
    • With the battery compartment closest to you, push the panel away from you. Once it slides back until it stops, gently lift it and put it to the side.
    • Please note that this particular screw does not completely come out, it stays with the rear panel and that is ok.
  3. HP Pavilion 17 TS Wireless Card Replacement, Wireless Card: adım 3, 3 resimden 1. HP Pavilion 17 TS Wireless Card Replacement, Wireless Card: adım 3, 3 resimden 2. HP Pavilion 17 TS Wireless Card Replacement, Wireless Card: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Undo the two clips attached to the wifi chip by pulling up gently with a pair of tweezers.
    • Unscrew the 9mm phillips screw holding the wifi chip in place.
    • Gently remove the wifi chip from its socket and place it to the side.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sean Croft
739 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-6, Miles Spring 2016 UMass Dartmouth, Team 1-6, Miles Spring 2016 üyesi
UMASSD-MILES-S16S1G6
3 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 294
