Giriş
The motherboard is a very important component to your HP Pavilion 17-ak008cy. like a majority of laptops it controls and regulates the the other components. It is important to handle this part with care to prevent further. This part has many fragile components so its important to careful when replacing this part.
Remove eleven screws from the back panel.
Remove the back panel from the device.
Use a Phillips #0 screwdriver to remove the single screw securing the fan to the motherboard.
Carefully detach the connector above the hard drive.
Remove the hard drive from the device.
