Ana içeriğe geç
HP Pavilion 17-ak008cy Motherboard Replacement
Neye ihtiyacın var
  1. HP Pavilion 17-ak008cy Motherboard Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the laptop over so that the underside is facing you.
  2. HP Pavilion 17-ak008cy Motherboard Replacement: adım 2, 3 resimden 1. HP Pavilion 17-ak008cy Motherboard Replacement: adım 2, 3 resimden 2. HP Pavilion 17-ak008cy Motherboard Replacement: adım 2, 3 resimden 3.
    • Using your hands, push the two tabs inwards to release the battery.
    • Remove the battery from the device.
  3. HP Pavilion 17-ak008cy Motherboard Replacement, Back Panel: adım 3, 2 resimden 1. HP Pavilion 17-ak008cy Motherboard Replacement, Back Panel: adım 3, 2 resimden 2.
    • Remove eleven screws from the back panel.
    • Remove the back panel from the device.
  4. HP Pavilion 17-ak008cy Motherboard Replacement, Fan: adım 4, 1 resimden 1.
    • Use a Phillips #0 screwdriver to remove the single screw securing the fan to the motherboard.
  5. HP Pavilion 17-ak008cy Motherboard Replacement: adım 5, 2 resimden 1. HP Pavilion 17-ak008cy Motherboard Replacement: adım 5, 2 resimden 2.
    • Disconnect the fan wire carefully so that the fan is longer connected to the motherboard.
  6. HP Pavilion 17-ak008cy Motherboard Replacement: adım 6, 2 resimden 1. HP Pavilion 17-ak008cy Motherboard Replacement: adım 6, 2 resimden 2.
    • Remove the fan from the device.
  7. HP Pavilion 17-ak008cy Motherboard Replacement, Hard Drive: adım 7, 2 resimden 1. HP Pavilion 17-ak008cy Motherboard Replacement, Hard Drive: adım 7, 2 resimden 2.
    • Carefully detach the connector above the hard drive.
    • Remove the hard drive from the device.
  8. HP Pavilion 17-ak008cy Motherboard Replacement, Motherboard: adım 8, 3 resimden 1. HP Pavilion 17-ak008cy Motherboard Replacement, Motherboard: adım 8, 3 resimden 2. HP Pavilion 17-ak008cy Motherboard Replacement, Motherboard: adım 8, 3 resimden 3.
    • Disconnect all of the cables attached to the motherboard.
    • Many of these wires are delicate so be careful when unplugging them.
  9. HP Pavilion 17-ak008cy Motherboard Replacement: adım 9, 2 resimden 1. HP Pavilion 17-ak008cy Motherboard Replacement: adım 9, 2 resimden 2.
    • Using a Phillips #0 screwdriver, remove eight screws from the motherboard.
    • Using the same screwdriver, remove four screws from the motherboard.
  10. HP Pavilion 17-ak008cy Motherboard Replacement: adım 10, 2 resimden 1. HP Pavilion 17-ak008cy Motherboard Replacement: adım 10, 2 resimden 2.
    • Gently lift and remove the motherboard from the device.
Sonuç
Andrew Boardman
487 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-2, Sinclaire Fall 2021 UMass Dartmouth, Team 2-2, Sinclaire Fall 2021 üyesi
UMASSD-SINCLAIRE-F21S2G2
3 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 169
