Ana içeriğe geç
HP Pavilion 17-ak008cy Speakers Replacement
Neye ihtiyacın var
  1. HP Pavilion 17-ak008cy Speakers Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the laptop over so that the underside is facing you.
  2. HP Pavilion 17-ak008cy Speakers Replacement: adım 2, 3 resimden 1. HP Pavilion 17-ak008cy Speakers Replacement: adım 2, 3 resimden 2. HP Pavilion 17-ak008cy Speakers Replacement: adım 2, 3 resimden 3.
    • Using your hands, push the two tabs inwards to release the battery.
    • Remove the battery from the device.
  3. HP Pavilion 17-ak008cy Speakers Replacement, Back Panel: adım 3, 2 resimden 1. HP Pavilion 17-ak008cy Speakers Replacement, Back Panel: adım 3, 2 resimden 2.
    • Remove eleven screws from the back panel.
    • Remove the back panel from the device.
  4. HP Pavilion 17-ak008cy Speakers Replacement, Speakers: adım 4, 3 resimden 1. HP Pavilion 17-ak008cy Speakers Replacement, Speakers: adım 4, 3 resimden 2. HP Pavilion 17-ak008cy Speakers Replacement, Speakers: adım 4, 3 resimden 3.
    • Using the Phillips #0 screwdriver, remove the two screws (one on each speaker) securing the speakers to the motherboard.
  5. HP Pavilion 17-ak008cy Speakers Replacement: adım 5, 2 resimden 1. HP Pavilion 17-ak008cy Speakers Replacement: adım 5, 2 resimden 2.
    • Gently unplug the speaker connector from the motherboard.
  6. HP Pavilion 17-ak008cy Speakers Replacement: adım 6, 2 resimden 1. HP Pavilion 17-ak008cy Speakers Replacement: adım 6, 2 resimden 2.
    • Carefully untangle the red wires tucked in between the black plastic tabs.
    • Remove the speakers from the device.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Andrew Boardman
487 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-2, Sinclaire Fall 2021 UMass Dartmouth, Team 2-2, Sinclaire Fall 2021 üyesi
UMASSD-SINCLAIRE-F21S2G2
3 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 104
