Ana içeriğe geç
HP Pavilion 17-e117dx Optical Drive Replacement
Neye ihtiyacın var
  1. HP Pavilion 17-e117dx Optical Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the laptop upside down, so that the bottom is facing up.
  2. HP Pavilion 17-e117dx Optical Drive Replacement: adım 2, 2 resimden 1. HP Pavilion 17-e117dx Optical Drive Replacement: adım 2, 2 resimden 2.
    • Slide the battery release latch to the left. The battery will pop up slightly.
    • Lift the battery upwards and out of the laptop.
  3. HP Pavilion 17-e117dx Optical Drive Replacement, Service Panel: adım 3, 2 resimden 1. HP Pavilion 17-e117dx Optical Drive Replacement, Service Panel: adım 3, 2 resimden 2.
    • Using a Phillips #00 screwdriver, remove the single Phillips 3.0 x 10.5 mm screw that fastens the service panel to the laptop.
  4. HP Pavilion 17-e117dx Optical Drive Replacement: adım 4, 1 resimden 1.
    • Slide the service panel towards you to loosen it from the laptop.
  5. HP Pavilion 17-e117dx Optical Drive Replacement: adım 5, 1 resimden 1.
    • Remove the service panel.
  6. HP Pavilion 17-e117dx Optical Drive Replacement, Optical Drive: adım 6, 2 resimden 1. HP Pavilion 17-e117dx Optical Drive Replacement, Optical Drive: adım 6, 2 resimden 2.
    • Remove the single Phillips PM 2.5 x 5.75 screw that secures the optical drive to the computer.
    • Use the Phillips #00 screwdriver.
  7. HP Pavilion 17-e117dx Optical Drive Replacement: adım 7, 3 resimden 1. HP Pavilion 17-e117dx Optical Drive Replacement: adım 7, 3 resimden 2. HP Pavilion 17-e117dx Optical Drive Replacement: adım 7, 3 resimden 3.
    • Slide the optical drive out of the computer.
Sonuç
Marcel Amazan
576 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S8-G5, Bailey Spring 2019 UMass Dartmouth, Team S8-G5, Bailey Spring 2019 üyesi
UMASSD-BAILEY-S19S8G5
2 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 350
