Ana içeriğe geç
HP Pavilion 17-e117dx WLAN Module Replacement
Neye ihtiyacın var
  1. HP Pavilion 17-e117dx WLAN Module Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the laptop upside down, so that the bottom is facing up.
  2. HP Pavilion 17-e117dx WLAN Module Replacement: adım 2, 2 resimden 1. HP Pavilion 17-e117dx WLAN Module Replacement: adım 2, 2 resimden 2.
    • Slide the battery release latch to the left. The battery will pop up slightly.
    • Lift the battery upwards and out of the laptop.
  3. HP Pavilion 17-e117dx WLAN Module Replacement, Service Panel: adım 3, 2 resimden 1. HP Pavilion 17-e117dx WLAN Module Replacement, Service Panel: adım 3, 2 resimden 2.
    • Using a Phillips #00 screwdriver, remove the single Phillips 3.0 x 10.5 mm screw that fastens the service panel to the laptop.
  4. HP Pavilion 17-e117dx WLAN Module Replacement: adım 4, 1 resimden 1.
    • Slide the service panel towards you to loosen it from the laptop.
  5. HP Pavilion 17-e117dx WLAN Module Replacement: adım 5, 1 resimden 1.
    • Remove the service panel.
  6. HP Pavilion 17-e117dx WLAN Module Replacement, WLAN Module: adım 6, 3 resimden 1. HP Pavilion 17-e117dx WLAN Module Replacement, WLAN Module: adım 6, 3 resimden 2. HP Pavilion 17-e117dx WLAN Module Replacement, WLAN Module: adım 6, 3 resimden 3.
    • Remove the two antenna cables from the top of the WLAN module by pulling them upwards.
    • Be gentle when removing the cables. You don't want to damage them.
  7. HP Pavilion 17-e117dx WLAN Module Replacement: adım 7, 2 resimden 1. HP Pavilion 17-e117dx WLAN Module Replacement: adım 7, 2 resimden 2.
    • Remove the single Phillips PM 2.5 x 3.25 screw so that you can remove the WLAN module from the system board.
    • Use the Phillips #00 screwdriver.
  8. HP Pavilion 17-e117dx WLAN Module Replacement: adım 8, 1 resimden 1.
    • To remove the WLAN module, pull it away from the slot at an angle.
Sonuç
Marcel Amazan
576 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S8-G5, Bailey Spring 2019 UMass Dartmouth, Team S8-G5, Bailey Spring 2019 üyesi
UMASSD-BAILEY-S19S8G5
2 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 4
Her zaman: 412
