Giriş
Replacing the WLAN module may be required when the HP Pavilion 17-e117dx cannot connect to a wireless network.
Before attempting to replace the WLAN module, make sure the laptop is powered off and nothing is plugged into the laptop. Also, make sure that the battery is removed.
Your hands must be clean and dry before beginning this procedure.
Neye ihtiyacın var
Using a Phillips #00 screwdriver, remove the single Phillips 3.0 x 10.5 mm screw that fastens the service panel to the laptop.
Remove the two antenna cables from the top of the WLAN module by pulling them upwards.
