Ana içeriğe geç
HP Pavilion 17-f004dx Hard Drive Replacement
Neye ihtiyacın var
  1. HP Pavilion 17-f004dx Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Before you remove the battery, make sure the laptop is powered off.
    • Slide the black battery latches inward to remove the battery.
  2. HP Pavilion 17-f004dx Hard Drive Replacement: adım 2, 1 resimden 1.
    • Pull the battery out towards you while your fingers are still holding the latches in place.
  3. HP Pavilion 17-f004dx Hard Drive Replacement, CD Drive: adım 3, 1 resimden 1.
    • Remove one 7 mm screw with a Phillips #1 screwdriver.
  4. HP Pavilion 17-f004dx Hard Drive Replacement: adım 4, 3 resimden 1. HP Pavilion 17-f004dx Hard Drive Replacement: adım 4, 3 resimden 2. HP Pavilion 17-f004dx Hard Drive Replacement: adım 4, 3 resimden 3.
    • Use a metal spudger to push the CD drive out of its slot for removal.
  5. HP Pavilion 17-f004dx Hard Drive Replacement, Front Panel: adım 5, 1 resimden 1.
    • Remove fifteen 7 mm screws with a Phillips #1 screwdriver.
  6. HP Pavilion 17-f004dx Hard Drive Replacement: adım 6, 2 resimden 1. HP Pavilion 17-f004dx Hard Drive Replacement: adım 6, 2 resimden 2.
    • Remove the thin plastic cover using the flat metal spudger to expose another screw.
    • Remove one 7 mm screw with a Phillips #0 screwdriver.
  7. HP Pavilion 17-f004dx Hard Drive Replacement: adım 7, 2 resimden 1. HP Pavilion 17-f004dx Hard Drive Replacement: adım 7, 2 resimden 2.
    • Use a metal spudger to remove the rubber "feet" to expose two screws.
  8. HP Pavilion 17-f004dx Hard Drive Replacement: adım 8, 1 resimden 1.
    • Underneath each rubber foot, there is a screw.
    • Use the Phillips #1 screwdriver to remove a 4.8 mm screw on each side.
  9. HP Pavilion 17-f004dx Hard Drive Replacement: adım 9, 1 resimden 1.
    • Remove the two black end caps to expose more screws.
    • The end caps will require some force to remove.
  10. HP Pavilion 17-f004dx Hard Drive Replacement: adım 10, 1 resimden 1.
    • Remove the following six screws with a Phillips #1 screwdriver:
    • Two 7 mm screws.
    • Two 7 mm screws.
    • Two 4.8 mm screws.
  11. HP Pavilion 17-f004dx Hard Drive Replacement: adım 11, 1 resimden 1.
    • Remove two 2.4 mm broadhead screws from the CD Drive bay with a Phillips #0 screwdriver.
  12. HP Pavilion 17-f004dx Hard Drive Replacement: adım 12, 2 resimden 1. HP Pavilion 17-f004dx Hard Drive Replacement: adım 12, 2 resimden 2.
    • Flip the laptop back over. Then, with the laptop open, move the plastic prying tool around the top cover to pry it from the enclosure.
  13. HP Pavilion 17-f004dx Hard Drive Replacement: adım 13, 1 resimden 1.
    • Partially lift the top cover from the enclosure.
  14. HP Pavilion 17-f004dx Hard Drive Replacement: adım 14, 2 resimden 1. HP Pavilion 17-f004dx Hard Drive Replacement: adım 14, 2 resimden 2.
    • Remove the ribbon connecting the power button to the motherboard.
  15. HP Pavilion 17-f004dx Hard Drive Replacement: adım 15, 2 resimden 1. HP Pavilion 17-f004dx Hard Drive Replacement: adım 15, 2 resimden 2.
    • Remove the ribbon connecting the mousepad to the motherboard.
  16. HP Pavilion 17-f004dx Hard Drive Replacement: adım 16, 2 resimden 1. HP Pavilion 17-f004dx Hard Drive Replacement: adım 16, 2 resimden 2.
    • Remove the ribbon connecting the keyboard to the motherboard.
    • You may now fully lift the front panel from the rest of the laptop.
  17. HP Pavilion 17-f004dx Hard Drive Replacement, Hard Drive: adım 17, 1 resimden 1.
    • Lift the black retaining bar that holds down the two hard drive ribbons to unlock them.
  18. HP Pavilion 17-f004dx Hard Drive Replacement: adım 18, 1 resimden 1.
    • Gently pull the ribbons out.
  19. HP Pavilion 17-f004dx Hard Drive Replacement: adım 19, 1 resimden 1.
    • Lift the hard drive out from the enclosure.
  20. HP Pavilion 17-f004dx Hard Drive Replacement: adım 20, 3 resimden 1. HP Pavilion 17-f004dx Hard Drive Replacement: adım 20, 3 resimden 2. HP Pavilion 17-f004dx Hard Drive Replacement: adım 20, 3 resimden 3.
    • Pull the rubber casing away from the hard drive.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Allan Soria
623 İtibar
4 adet Kılavuz yazıldı
Ekip
UC Davis, Team 1-4, Oliver Fall 2016 UC Davis, Team 1-4, Oliver Fall 2016 üyesi
UCD-OLIVER-F16S1G4
4 Üyeler
8 adet Kılavuz yazıldı
Bir Yorum
Thank you. Couldn’t figure out why those end caps wouldn’t budge. Dang hidden screws! Kudos!
Shaun Krug - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 15
Her zaman: 6,308
