Ana içeriğe geç
HP Pavilion 17-f127ds Optical Drive Replacement
Neye ihtiyacın var
  1. HP Pavilion 17-f127ds Optical Drive Replacement, Battery: adım 1, 3 resimden 1. HP Pavilion 17-f127ds Optical Drive Replacement, Battery: adım 1, 3 resimden 2. HP Pavilion 17-f127ds Optical Drive Replacement, Battery: adım 1, 3 resimden 3.
    • Before starting, please turn off your laptop.
    • Slide the battery lock latch, the latch on the left, inwards.
    • Slide the battery release latch on the right inwards to release the battery.
    • The latch may require significant force to slide.
    • Lift the battery up and remove it from computer.
  2. HP Pavilion 17-f127ds Optical Drive Replacement, Optical Drive: adım 2, 2 resimden 1. HP Pavilion 17-f127ds Optical Drive Replacement, Optical Drive: adım 2, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the screw holding the Optical Drive in place. It is located near the center and vents of the laptop.
    • Use a spudger to help unseat the drive. Pull the drive out from the laptop.
  3. HP Pavilion 17-f127ds Optical Drive Replacement: adım 3, 1 resimden 1.
    • If you need to replace the bracket on the Optical drive, remove the two Phillips #0 screws holding the bracket in place. The bracket can be placed on the new drive.
Sonuç
Stephen Brown
201 İtibar
2 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S3-G1, Liner Fall 2017 UW Tacoma, Team S3-G1, Liner Fall 2017 üyesi
UWT-LINER-F17S3G1
5 Üyeler
4 adet Kılavuz yazıldı
Bir Yorum
I can’t remove the HP Pavilion 17-x016ds Optical Drive. NEED HELP. Is it necessary to remove it in order to remove bottom panel to replace HDD with SSD? Also can’t remove bottom panel.
Nick Koriakin - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 931
